O que você precisa
Pry open the rubber I/F terminal cap with your finger.
Remove the two M1.7x2.5mm JIS #000 screws that are underneath the I/F terminal cap.
Using a plastic pick, or another thin plastic prying tool, pop off the I/F terminal cover from the camera.
On the left side of the camera, remove the following screw:
One M1.7x6.0mm JIS #000 screw
On the right side, remove the following screws:
One M1.7x5.5mm JIS #000 screw
One M1.7x3.5mm JIS #000 screw
Slide the viewfinder eyepiece vertically upwards.
Start to pull the back cover partially off of the camera.
Disconnect the LCD screen ribbon cable from the main PCB board.
Use a plastic spudger to lift up the black locking tab.
Carefully pull out the ribbon cable from its connector using a pair of angled tweezers.
Finish pulling the back cover off of the camera body.
Remove the following screws from the front of the camera:
Two M1.7x5.5mm JIS #000 screws
On the bottom of the camera, remove the following screws:
Three M1.7x5.5mm JIS #000 screws
Remove the screws next to the viewfinder:
Two M1.7x2.5mm JIS #000 screws
One M2.0x8.9mm JIS #000 diopter screw
Remove the following screws from the top of the camera:
One M1.7x2.5mm JIS #000 screw
One M1.7x5.0mm Phillips #000 screw
Disconnect these two cables connected to the DC PCB board.
Use the same method as with removing the microphone cable, except with using a flathead 3.0mm screwdriver.
Gently wiggle the flathead screwdriver back and forth until the connectors comes free.
Gently lift the top cover up and off of the camera body, being careful that the loose cables do not snag on anything.
On the left side of the camera, remove the following screws:
Two M2.0x2.5mm JIS #000 screws
On the right side of the camera, remove the following screws:
Two M2.0x6.0mm JIS #000 screws
