Ir para o conteúdo principal
Canon EOS 6D Rear Body Panel Replacement
O que você precisa
    1. Canon EOS 6D Rear Body Panel Replacement, Rear Body Panel: passo 1, imagem 1 %32
      • Remove the viewfinder cover by pinching the sides and sliding it upward.
      Pergunte ao FixBot
      Comentar
    2. Canon EOS 6D Rear Body Panel Replacement: passo 2, imagem 1 %32
      • Open the battery door on the bottom of the camera.
      • Use your thumb to slide the small black tab on the inside of the battery door up and pull the door off the camera.
      Pergunte ao FixBot
      Comentar
    3. Canon EOS 6D Rear Body Panel Replacement: passo 3, imagem 1 %32
      • Slide your fingernail or the flat end of the spudger underneath the rubber covering and gently peel it off all sides of the camera.
      Pergunte ao FixBot
      Comentar
    4. Canon EOS 6D Rear Body Panel Replacement: passo 4, imagem 1 %32
      • Open the covers to the HDMI/AV/MIC ports on the side of the camera by gently pulling outward on the bottom of the covers.
      • Rotate the covers to the side so that you can see the connection ports inside.
      • Remove the following screws:
      • Two silver 5mm Phillips #00
      • One black 6mm Phillips #00
      Pergunte ao FixBot
      Comentar
    5. Canon EOS 6D Rear Body Panel Replacement: passo 5, imagem 1 %32
      • Remove the cover to the HDMI/AV/MIC ports by gently lifting the tab on the bottom edge of the camera.
      Pergunte ao FixBot
      Comentar
    6. Canon EOS 6D Rear Body Panel Replacement: passo 6, imagem 1 %32
      • Rotate your camera so the bottom side is facing you.
      • One 6mm Phillips #00
      • Two 3mm Phillips #00
      Pergunte ao FixBot
      Comentar
    7. Canon EOS 6D Rear Body Panel Replacement: passo 7, imagem 1 %32
      • Rotate your camera so the back is facing you.
      • Three silver 5mm Phillips #00
      • Two black 6mm Phillips #00
      • One black 4mm Phillips #00
      Pergunte ao FixBot
      Comentar
    8. Canon EOS 6D Rear Body Panel Replacement: passo 8, imagem 1 %32 Canon EOS 6D Rear Body Panel Replacement: passo 8, imagem 2 %32
      • A black ribbon wire connects the rear panel to the inside of the camera. Breaking this wire would make your rear screen and buttons non-functional.
      • Carefully use your fingers to tilt the back panel downward to about a 90 degree angle.
      • Use the flat end of the spudger to gently pry off the ribbon wire from the inside of the camera.
      Pergunte ao FixBot
      Comentar
Conclusão
12 outras pessoas executaram este guia.
Justin Thomas
Membro desde: 04/22/14
2.233 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 11-48, Amido Spring 2014 Membro de Cal Poly, Team 11-48, Amido Spring 2014
CPSU-AMIDO-S14S11G48
4 Membros
Autoria de 20 guias
2Comentários do guia
Thanks alot, very helpful
busulwa paddy - Responder Compartilhar
Thanks alot, very helpful fixed an issue
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 14
Últimos 30 dias: 69
Ao todo: 11,015
