Ir para o conteúdo principal
Canon EOS 5D Mark II Top Panel Replacement
O que você precisa
    1. Canon EOS 5D Mark II Top Panel Replacement, Clock Battery: passo 1, imagem 1 %32
      • Lift the rubber flap covering the input/output jacks.
      Pergunte ao FixBot
      Comentar
    2. Canon EOS 5D Mark II Top Panel Replacement: passo 2, imagem 1 %32
      • Using a Phillips #000, remove the single 3.4 mm screw.
      Pergunte ao FixBot
      Comentar
    3. Canon EOS 5D Mark II Top Panel Replacement: passo 3, imagem 1 %32
      • This step will permanently erase all user settings.
      • The memory battery can now be easily slid out of place.
      • If you are following this guide in an effort to perform a hard reset, you should now press the shutter button multiple times in order to drain any left over power, then replace the batteries and power the device back on. You have just performed a hard reset!
      Pergunte ao FixBot
      Comentar
    1. Canon EOS 5D Mark II Top Panel Replacement, Back Panel: passo 4, imagem 1 %32
      • Peel back the rubber cover above the in/out ports to reveal two screw heads.
      Pergunte ao FixBot
      Comentar
    2. Canon EOS 5D Mark II Top Panel Replacement: passo 5, imagem 1 %32
      • Remove both 5.4 mm screws using a Phillips #0.
      Pergunte ao FixBot
      Comentar
    3. Canon EOS 5D Mark II Top Panel Replacement: passo 6, imagem 1 %32
      • Lift the in/out port plastic covering from the bottom where the backup battery used to be.
      Pergunte ao FixBot
      Comentar
    4. Canon EOS 5D Mark II Top Panel Replacement: passo 7, imagem 1 %32
      • Remove each 6.3 mm screw on either side of the viewfinder using a Phillips #0 screwdriver.
      Pergunte ao FixBot
      Comentar
    5. Canon EOS 5D Mark II Top Panel Replacement: passo 8, imagem 1 %32
      • Remove the three 4.8 mm screws on the bottom of the back plate using a Phillips #0.
      Pergunte ao FixBot
      Comentar
    6. Canon EOS 5D Mark II Top Panel Replacement: passo 9, imagem 1 %32
      • Peel back the rubber covering next to the menu dial to access the screw.
      • Remove the single 3.4 mm screw using a Phillips #0.
      Pergunte ao FixBot
      Comentar
    7. Canon EOS 5D Mark II Top Panel Replacement: passo 10, imagem 1 %32
      • The back panel can now fall off easily by turning the device upside down. Be sure to catch it so the data ribbons do not tear or tug.
      Pergunte ao FixBot
      Comentar
    8. Canon EOS 5D Mark II Top Panel Replacement: passo 11, imagem 1 %32
      • Remove each data ribbon cable from the motherboard by applying pressure down towards the motherboard and gently sliding your thumb upwards on the slot where the cable meets the motherboard. This will raise a very small clip that locks the cable in place.
      • The back panel is now free from the rest of the device.
      Pergunte ao FixBot
      Comentar
    1. Canon EOS 5D Mark II Top Panel Replacement, Front Panel: passo 12, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Using tweezers, pull out the wire attaching the front panel to the motherboard.
      Pergunte ao FixBot
      Comentar
    2. Canon EOS 5D Mark II Top Panel Replacement: passo 13, imagem 1 %32
      • Peel off the rubber cover on the front panel in order to access the screws underneath.
      Pergunte ao FixBot
      Comentar
    3. Canon EOS 5D Mark II Top Panel Replacement: passo 14, imagem 1 %32
      • Remove each of the 4.9 mm three screws using a Phillips #0.
      Pergunte ao FixBot
      Comentar
    4. Canon EOS 5D Mark II Top Panel Replacement: passo 15, imagem 1 %32
      • Remove the two 4.8 mm screws above where the lens would be using a Phillips #0.
      Pergunte ao FixBot
      Comentar
    5. Canon EOS 5D Mark II Top Panel Replacement: passo 16, imagem 1 %32
      • Remove the single screw underneath where the lens would be using a Phillips #0.
      Pergunte ao FixBot
      Comentar
    6. Canon EOS 5D Mark II Top Panel Replacement: passo 17, imagem 1 %32 Canon EOS 5D Mark II Top Panel Replacement: passo 17, imagem 2 %32 Canon EOS 5D Mark II Top Panel Replacement: passo 17, imagem 3 %32
      • Remove the four 3.0 mm screws next to the memory card reader using a Phillips #0.
      Pergunte ao FixBot
      Comentar
    7. Canon EOS 5D Mark II Top Panel Replacement: passo 18, imagem 1 %32 Canon EOS 5D Mark II Top Panel Replacement: passo 18, imagem 2 %32
      • Remove the front panel by lifting upwards from the right side where the in/out ports used to be.
      Pergunte ao FixBot
      Comentar
    1. Canon EOS 5D Mark II Top Panel Replacement, Top Panel: passo 19, imagem 1 %32
      • Remove the single 5.9 mm screw next to the the strap loop on the same side as the shutter button.
      Pergunte ao FixBot
      Comentar
    2. Canon EOS 5D Mark II Top Panel Replacement: passo 20, imagem 1 %32
      • Remove the single 3.8 mm screw underneath the camera strap on the same side as the in/out ports.
      • If you are having problems finding this screw, note the orientation of the viewfinder in the bottom center of the photo.
      Pergunte ao FixBot
      Comentar
    3. Canon EOS 5D Mark II Top Panel Replacement: passo 21, imagem 1 %32 Canon EOS 5D Mark II Top Panel Replacement: passo 21, imagem 2 %32
      • Using tweezers or your thumb, raise the clasp holding the topmost data ribbon cable in order to release it.
      Pergunte ao FixBot
      Comentar
    4. Canon EOS 5D Mark II Top Panel Replacement: passo 22, imagem 1 %32
      • The top panel is now free from the rest of the device. Lift to remove.
      Pergunte ao FixBot
      Comentar
Conclusão
15 outras pessoas executaram este guia.
Mike Seed
Membro desde: 09/22/14
3.166 Reputação
Autoria de 8 guias
Equipe
USF Tampa, Team 1-6, Hickman Fall 2014 Membro de USF Tampa, Team 1-6, Hickman Fall 2014
USFT-HICKMAN-F14S1G6
3 Membros
Autoria de 17 guias
13Comentários do guia
The strap hook on the left side of my 5d2 body got bent in a fall and I want to replace it. Do I have to go through all these steps or is there an easier way to get to it ? Thanks
Tim - Responder Compartilhar
Everything it's very nice in this guide.
I just have a question?
Where do I can find the top panel to buy it?
It's seem almost impossible...
stefano masetti - Responder Compartilhar
I would also like to know where a replacement top panel can be purchased from.
t1000email - Responder Compartilhar
I purchased one on Ebay , (US) $100 USD
yanhao996 - Responder Compartilhar
The guide is useful and quite easy to follow. Thanks
Janes - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 59
Ao todo: 15,935
