Ir para o conteúdo principal
Canon EOS 300 Command Dial Replacement
O que você precisa
    1. Canon EOS 300 Command Dial Replacement, Batteries: passo 1, imagem 1 %32 Canon EOS 300 Command Dial Replacement, Batteries: passo 1, imagem 2 %32 Canon EOS 300 Command Dial Replacement, Batteries: passo 1, imagem 3 %32
      • Open up the battery door.
      Pergunte ao FixBot
      Comentar
    2. Canon EOS 300 Command Dial Replacement: passo 2, imagem 1 %32 Canon EOS 300 Command Dial Replacement: passo 2, imagem 2 %32
      • Remove the batteries from the camera by sliding them out into your palm.
      Pergunte ao FixBot
      Comentar
    1. Canon EOS 300 Command Dial Replacement, Side Panel with Lever: passo 3, imagem 1 %32 Canon EOS 300 Command Dial Replacement, Side Panel with Lever: passo 3, imagem 2 %32
      • Release the side latch to open the back panel.
      Pergunte ao FixBot
      Comentar
    2. Canon EOS 300 Command Dial Replacement: passo 4, imagem 1 %32 Canon EOS 300 Command Dial Replacement: passo 4, imagem 2 %32
      • Remove the two black 4.5mm screws above and below the latch.
      Pergunte ao FixBot
      Comentar
    3. Canon EOS 300 Command Dial Replacement: passo 5, imagem 1 %32 Canon EOS 300 Command Dial Replacement: passo 5, imagem 2 %32
      • Using your finger, carefully pry open the side panel from the top of camera.
      • Pull panel downwards to remove.
      • Make sure to keep track of the small black piece of rubber under the latch.
      Pergunte ao FixBot
      Comentar
    1. Canon EOS 300 Command Dial Replacement, Front Panel: passo 6, imagem 1 %32 Canon EOS 300 Command Dial Replacement, Front Panel: passo 6, imagem 2 %32
      • Remove the two silver 6mm Phillips #1 screws.
      Pergunte ao FixBot
      Comentar
    2. Canon EOS 300 Command Dial Replacement: passo 7, imagem 1 %32 Canon EOS 300 Command Dial Replacement: passo 7, imagem 2 %32
      • Flip camera over to the bottom.
      • Remove the one 5mm Phillips #1 silver screw.
      Pergunte ao FixBot
      Comentar
    3. Canon EOS 300 Command Dial Replacement: passo 8, imagem 1 %32 Canon EOS 300 Command Dial Replacement: passo 8, imagem 2 %32
      • Remove the front panel by pulling away from the side with the lever.
      Pergunte ao FixBot
      Comentar
    1. Canon EOS 300 Command Dial Replacement, Bottom Panel: passo 9, imagem 1 %32 Canon EOS 300 Command Dial Replacement, Bottom Panel: passo 9, imagem 2 %32
      • Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
      • Remove five black 4.8mm Phillips #1 screws.
      Pergunte ao FixBot
      Comentar
    2. Canon EOS 300 Command Dial Replacement: passo 10, imagem 1 %32 Canon EOS 300 Command Dial Replacement: passo 10, imagem 2 %32 Canon EOS 300 Command Dial Replacement: passo 10, imagem 3 %32
      • Simply remove the bottom panel by prying it off with your finger.
      • When removing the panel, be sure the bottom of the camera is facing upright. There are loose gears that may fall out.
      • Be wary of a loose piece of foam attached to the bottom panel.
      Pergunte ao FixBot
      Comentar
    1. Canon EOS 300 Command Dial Replacement, Side Panel with Grip: passo 11, imagem 1 %32 Canon EOS 300 Command Dial Replacement, Side Panel with Grip: passo 11, imagem 2 %32 Canon EOS 300 Command Dial Replacement, Side Panel with Grip: passo 11, imagem 3 %32
      • Remove the remote control socket cover.
      Pergunte ao FixBot
      Comentar
    2. Canon EOS 300 Command Dial Replacement: passo 12, imagem 1 %32 Canon EOS 300 Command Dial Replacement: passo 12, imagem 2 %32
      • Remove two black 4.5mm Phillips #1 screws.
      Pergunte ao FixBot
      Comentar
    3. Canon EOS 300 Command Dial Replacement: passo 13, imagem 1 %32 Canon EOS 300 Command Dial Replacement: passo 13, imagem 2 %32
      • Remove two black 4.8mm Phillips #1 screws on the front of the camera.
      Pergunte ao FixBot
      Comentar
    4. Canon EOS 300 Command Dial Replacement: passo 14, imagem 1 %32 Canon EOS 300 Command Dial Replacement: passo 14, imagem 2 %32
      • Pry open the side grip using a spudger.
      Pergunte ao FixBot
      Comentar
    1. Canon EOS 300 Command Dial Replacement, Eyecup: passo 15, imagem 1 %32 Canon EOS 300 Command Dial Replacement, Eyecup: passo 15, imagem 2 %32
      • With your hands, remove the rubber grip from the eye piece.
      Pergunte ao FixBot
      Comentar
    2. Canon EOS 300 Command Dial Replacement: passo 16, imagem 1 %32
      • Remove the eyecup from the eyepiece by pushing the eyecup up.
      Pergunte ao FixBot
      Comentar
    1. Canon EOS 300 Command Dial Replacement, Top Panel: passo 17, imagem 1 %32 Canon EOS 300 Command Dial Replacement, Top Panel: passo 17, imagem 2 %32
      • Remove two silver 5.0mm Phillips #1 screws.
      Pergunte ao FixBot
      Comentar
    2. Canon EOS 300 Command Dial Replacement: passo 18, imagem 1 %32
      • Remove the silver 5.5mm Phillips #1 screw.
      Pergunte ao FixBot
      Comentar
    3. Canon EOS 300 Command Dial Replacement: passo 19, imagem 1 %32 Canon EOS 300 Command Dial Replacement: passo 19, imagem 2 %32
      • Pry the top silver part of the camera off.
      • Buttons may slip out of the camera's top as the top is pulled off the camera (shown in picture two).
      Pergunte ao FixBot
      Comentar
    1. Canon EOS 300 Command Dial Replacement, Command Dial: passo 20, imagem 1 %32 Canon EOS 300 Command Dial Replacement, Command Dial: passo 20, imagem 2 %32 Canon EOS 300 Command Dial Replacement, Command Dial: passo 20, imagem 3 %32
      • On the top panel, remove the silver 3.8mm Phillips #1 screw right below the command dial.
      • A small metal piece will come off with the screw.
      Pergunte ao FixBot
      Comentar
Conclusão
Tammy Kong
Membro desde: 01/23/14
805 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 6-20, Maness Winter 2014 Membro de Cal Poly, Team 6-20, Maness Winter 2014
CPSU-MANESS-W14S6G20
4 Membros
Autoria de 55 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 49
Ao todo: 2,427
