Ir para o conteúdo principal
Canon EOS 300 Bottom Panel Replacement
O que você precisa
    1. Canon EOS 300 Bottom Panel Replacement, Batteries: passo 1, imagem 1 %32 Canon EOS 300 Bottom Panel Replacement, Batteries: passo 1, imagem 2 %32 Canon EOS 300 Bottom Panel Replacement, Batteries: passo 1, imagem 3 %32
      • Open up the battery door.
      Pergunte ao FixBot
      Comentar
    2. Canon EOS 300 Bottom Panel Replacement: passo 2, imagem 1 %32 Canon EOS 300 Bottom Panel Replacement: passo 2, imagem 2 %32
      • Remove the batteries from the camera by sliding them out into your palm.
      Pergunte ao FixBot
      Comentar
    1. Canon EOS 300 Bottom Panel Replacement, Side Panel with Lever: passo 3, imagem 1 %32 Canon EOS 300 Bottom Panel Replacement, Side Panel with Lever: passo 3, imagem 2 %32
      • Release the side latch to open the back panel.
      Pergunte ao FixBot
      Comentar
    2. Canon EOS 300 Bottom Panel Replacement: passo 4, imagem 1 %32 Canon EOS 300 Bottom Panel Replacement: passo 4, imagem 2 %32
      • Remove the two black 4.5mm screws above and below the latch.
      Pergunte ao FixBot
      Comentar
    3. Canon EOS 300 Bottom Panel Replacement: passo 5, imagem 1 %32 Canon EOS 300 Bottom Panel Replacement: passo 5, imagem 2 %32
      • Using your finger, carefully pry open the side panel from the top of camera.
      • Pull panel downwards to remove.
      • Make sure to keep track of the small black piece of rubber under the latch.
      Pergunte ao FixBot
      Comentar
    1. Canon EOS 300 Bottom Panel Replacement, Front Panel: passo 6, imagem 1 %32 Canon EOS 300 Bottom Panel Replacement, Front Panel: passo 6, imagem 2 %32
      • Remove the two silver 6mm Phillips #1 screws.
      Pergunte ao FixBot
      Comentar
    2. Canon EOS 300 Bottom Panel Replacement: passo 7, imagem 1 %32 Canon EOS 300 Bottom Panel Replacement: passo 7, imagem 2 %32
      • Flip camera over to the bottom.
      • Remove the one 5mm Phillips #1 silver screw.
      Pergunte ao FixBot
      Comentar
    3. Canon EOS 300 Bottom Panel Replacement: passo 8, imagem 1 %32 Canon EOS 300 Bottom Panel Replacement: passo 8, imagem 2 %32
      • Remove the front panel by pulling away from the side with the lever.
      Pergunte ao FixBot
      Comentar
    1. Canon EOS 300 Bottom Panel Replacement, Bottom Panel: passo 9, imagem 1 %32 Canon EOS 300 Bottom Panel Replacement, Bottom Panel: passo 9, imagem 2 %32
      • Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
      • Remove five black 4.8mm Phillips #1 screws.
      Pergunte ao FixBot
      Comentar
    2. Canon EOS 300 Bottom Panel Replacement: passo 10, imagem 1 %32 Canon EOS 300 Bottom Panel Replacement: passo 10, imagem 2 %32 Canon EOS 300 Bottom Panel Replacement: passo 10, imagem 3 %32
      • Simply remove the bottom panel by prying it off with your finger.
      • When removing the panel, be sure the bottom of the camera is facing upright. There are loose gears that may fall out.
      • Be wary of a loose piece of foam attached to the bottom panel.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Tammy Kong
Membro desde: 01/23/14
805 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 6-20, Maness Winter 2014 Membro de Cal Poly, Team 6-20, Maness Winter 2014
CPSU-MANESS-W14S6G20
4 Membros
Autoria de 55 guias
1Comentário do guia
muy buena la explicacion de como desmontar la maquina. Te has gadano los 30 puntos
Ricardo Alonso Gurrea - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 23
Ao todo: 1,217
