Ir para o conteúdo principal
Canon EOS 300 Back Lock-Release Lever Replacement
O que você precisa
    1. Canon EOS 300 Back Lock-Release Lever Replacement, Batteries: passo 1, imagem 1 %32 Canon EOS 300 Back Lock-Release Lever Replacement, Batteries: passo 1, imagem 2 %32 Canon EOS 300 Back Lock-Release Lever Replacement, Batteries: passo 1, imagem 3 %32
      • Open up the battery door.
      Pergunte ao FixBot
      Comentar
    2. Canon EOS 300 Back Lock-Release Lever Replacement: passo 2, imagem 1 %32 Canon EOS 300 Back Lock-Release Lever Replacement: passo 2, imagem 2 %32
      • Remove the batteries from the camera by sliding them out into your palm.
      Pergunte ao FixBot
      Comentar
    1. Canon EOS 300 Back Lock-Release Lever Replacement, Side Panel with Lever: passo 3, imagem 1 %32 Canon EOS 300 Back Lock-Release Lever Replacement, Side Panel with Lever: passo 3, imagem 2 %32
      • Release the side latch to open the back panel.
      Pergunte ao FixBot
      Comentar
    2. Canon EOS 300 Back Lock-Release Lever Replacement: passo 4, imagem 1 %32 Canon EOS 300 Back Lock-Release Lever Replacement: passo 4, imagem 2 %32
      • Remove the two black 4.5mm screws above and below the latch.
      Pergunte ao FixBot
      Comentar
    3. Canon EOS 300 Back Lock-Release Lever Replacement: passo 5, imagem 1 %32 Canon EOS 300 Back Lock-Release Lever Replacement: passo 5, imagem 2 %32
      • Using your finger, carefully pry open the side panel from the top of camera.
      • Pull panel downwards to remove.
      • Make sure to keep track of the small black piece of rubber under the latch.
      Pergunte ao FixBot
      Comentar
    1. Canon EOS 300 Back Lock-Release Lever Replacement, Front Panel: passo 6, imagem 1 %32 Canon EOS 300 Back Lock-Release Lever Replacement, Front Panel: passo 6, imagem 2 %32
      • Remove the two silver 6mm Phillips #1 screws.
      Pergunte ao FixBot
      Comentar
    2. Canon EOS 300 Back Lock-Release Lever Replacement: passo 7, imagem 1 %32 Canon EOS 300 Back Lock-Release Lever Replacement: passo 7, imagem 2 %32
      • Flip camera over to the bottom.
      • Remove the one 5mm Phillips #1 silver screw.
      Pergunte ao FixBot
      Comentar
    3. Canon EOS 300 Back Lock-Release Lever Replacement: passo 8, imagem 1 %32 Canon EOS 300 Back Lock-Release Lever Replacement: passo 8, imagem 2 %32
      • Remove the front panel by pulling away from the side with the lever.
      Pergunte ao FixBot
      Comentar
    1. Canon EOS 300 Back Lock-Release Lever Replacement, Back Lock-Release Lever: passo 9, imagem 1 %32 Canon EOS 300 Back Lock-Release Lever Replacement, Back Lock-Release Lever: passo 9, imagem 2 %32 Canon EOS 300 Back Lock-Release Lever Replacement, Back Lock-Release Lever: passo 9, imagem 3 %32
      • Pull off the lever by pushing up from the bottom and pulling away from the bottom.
      Pergunte ao FixBot
      Comentar
Conclusão
Jordan Tang
Membro desde: 01/24/14
608 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 6-20, Maness Winter 2014 Membro de Cal Poly, Team 6-20, Maness Winter 2014
CPSU-MANESS-W14S6G20
4 Membros
Autoria de 32 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 54
Ao todo: 2,743
