Ir para o conteúdo principal
Canon EOS 30 Remote Control Socket Replacement
O que você precisa
  1. Canon EOS 30 Remote Control Socket Replacement, Front Panel: passo 1, imagem 1 %32
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
    Pergunte ao FixBot
    Comentar
  2. Canon EOS 30 Remote Control Socket Replacement: passo 2, imagem 1 %32
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
    Pergunte ao FixBot
    Comentar
  3. Canon EOS 30 Remote Control Socket Replacement: passo 3, imagem 1 %32
    • Remove the 4.8 mm black screw on the left side of the camera.
    Pergunte ao FixBot
    Comentar
  4. Canon EOS 30 Remote Control Socket Replacement: passo 4, imagem 1 %32
    • Remove the front panel by lifting it away from the camera's body.
    Pergunte ao FixBot
    Comentar
  5. Canon EOS 30 Remote Control Socket Replacement, Bottom Panel: passo 5, imagem 1 %32
    • Remove seven 4.25 mm black screws on the bottom panel.
    Pergunte ao FixBot
    Comentar
  6. Canon EOS 30 Remote Control Socket Replacement: passo 6, imagem 1 %32
    • Remove the bottom panel.
    Pergunte ao FixBot
    Comentar
  7. Canon EOS 30 Remote Control Socket Replacement, Side Panel With Remote Control Socket: passo 7, imagem 1 %32
    • Remove two 6.5 mm black screws from the panel.
    Pergunte ao FixBot
    Comentar
  8. Canon EOS 30 Remote Control Socket Replacement: passo 8, imagem 1 %32
    • Remove the plastic remote control socket cap by pulling it straight out.
    Pergunte ao FixBot
    Comentar
  9. Canon EOS 30 Remote Control Socket Replacement: passo 9, imagem 1 %32 Canon EOS 30 Remote Control Socket Replacement: passo 9, imagem 2 %32
    • Slide the panel toward the bottom of the camera to remove.
    Pergunte ao FixBot
    Comentar
  10. Canon EOS 30 Remote Control Socket Replacement: passo 10, imagem 1 %32
    • Remove the single 4.8 silver screw from the control socket.
    Pergunte ao FixBot
    Comentar
  11. Canon EOS 30 Remote Control Socket Replacement: passo 11, imagem 1 %32 Canon EOS 30 Remote Control Socket Replacement: passo 11, imagem 2 %32
    • The control socket is now secure by three wires.
    • Desolder connections to replace the remote control socket.
    Pergunte ao FixBot
    Comentar
  12. Canon EOS 30 Remote Control Socket Replacement, Remote Control Socket: passo 12, imagem 1 %32
    • Remove one 4.8 mm silver screw securing Remote Control Socket to camera.
    Pergunte ao FixBot
    Comentar
  13. Canon EOS 30 Remote Control Socket Replacement: passo 13, imagem 1 %32 Canon EOS 30 Remote Control Socket Replacement: passo 13, imagem 2 %32
    • Remote Control Socket is now secured by 3 wires.
    • Desolder connections to replace Remote Control Socket.
    Pergunte ao FixBot
    Comentar
Conclusão
Antonia
Membro desde: 04/17/11
124 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 8-8, Regan Spring 2011 Membro de Cal Poly, Team 8-8, Regan Spring 2011
CPSU-REGAN-S11S8G8
5 Membros
Autoria de 22 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 42
Ao todo: 3,417
