Ir para o conteúdo principal
Cable set up
  1. Cable set up, Cable set up: passo 1, imagem 1 %32
    • Check that the red RCA plug is connected to the red RCA jack labeled "R" (this indicates the Right speaker).
    • Check that the white RCA plug is connected to the white RCA jack labeled "L" (this indicates the Left speaker).
    • To connect the ground clip, loosen the ground screw and insert the clip. Once clip is secure tighten the screw.
    Pergunte ao FixBot
    Comentar
  2. Cable set up: passo 2, imagem 1 %32
    • Check the voltage selector switch to make sure its set to the proper voltage depending on your geographic location.
    • Voltage selector should be set to 115 V/60 Hz in the U.S., or 230 V/50 Hz in other countries.
    Pergunte ao FixBot
    Comentar
  3. Cable set up: passo 3, imagem 1 %32
    • Insert power cable into socket.
    Pergunte ao FixBot
    Comentar
Linha de Chegada
Nikolai
Membro desde: 10/12/11
281 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 17-14, Regan Fall 2011 Membro de Cal Poly, Team 17-14, Regan Fall 2011
CPSU-REGAN-F11S17G14
4 Membros
Autoria de 11 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 27
Ao todo: 1,246
