Ir para o conteúdo principal
CM Storm QuickFire Rapid Switch Replacement
O que você precisa
  1. CM Storm QuickFire Rapid Switch Replacement, Switch: passo 1, imagem 1 %32 CM Storm QuickFire Rapid Switch Replacement, Switch: passo 1, imagem 2 %32
  2. CM Storm QuickFire Rapid Switch Replacement, Remove screw on back of keyboard (labeled do not remove): passo 2, imagem 1 %32 CM Storm QuickFire Rapid Switch Replacement, Remove screw on back of keyboard (labeled do not remove): passo 2, imagem 2 %32
    • Using a Philips #0 screwdriver, remove the .5cm screw from the back of the keyboard.
    • This will void your warranty!
    • When inserting the screw after replacing the switch, make sure to not screw in too tight. This may cause erratic behavior with the keyboard.
  3. CM Storm QuickFire Rapid Switch Replacement, Seperating Back Panel from Front Panel: passo 3, imagem 1 %32 CM Storm QuickFire Rapid Switch Replacement, Seperating Back Panel from Front Panel: passo 3, imagem 2 %32 CM Storm QuickFire Rapid Switch Replacement, Seperating Back Panel from Front Panel: passo 3, imagem 3 %32
    • Wedge a plastic opening tool between the rear plate and rim of the keyboard and slide it through the circled areas to separate the plastic hooks that mount the rim to the rear plate.
  4. CM Storm QuickFire Rapid Switch Replacement, Opening Back Panel: passo 4, imagem 1 %32 CM Storm QuickFire Rapid Switch Replacement, Opening Back Panel: passo 4, imagem 2 %32
    • Firmly grasp the bottom panel of the keyboard and carefully detach it from the rest of the board.
    • Do not put strain on the ribbon cable when lifting the bottom panel.
  5. CM Storm QuickFire Rapid Switch Replacement, Detaching SIL Connector: passo 5, imagem 1 %32 CM Storm QuickFire Rapid Switch Replacement, Detaching SIL Connector: passo 5, imagem 2 %32
    • Detach the 4-pin cable from the bottom panel of the keyboard.
  6. CM Storm QuickFire Rapid Switch Replacement, Desolder Switch Solder Joints: passo 6, imagem 1 %32
    • Desolder the joints holding the switch to the board.
    • Remove the switch and solder the new switch in place.
Conclusão
9 outras pessoas executaram este guia.
Andrew
Membro desde: 10/12/14
321 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 6-23, Maness Fall 2014 Membro de Cal Poly, Team 6-23, Maness Fall 2014
CPSU-MANESS-F14S6G23
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 51
Ao todo: 16,969
