Ir para o conteúdo principal
CM Storm QuickFire Rapid O-ring: Large Keycap Installation
O que você precisa
  1. CM Storm QuickFire Rapid O-ring: Large Keycap Installation, O-ring: Large Keycap: passo 1, imagem 1 %32 CM Storm QuickFire Rapid O-ring: Large Keycap Installation, O-ring: Large Keycap: passo 1, imagem 2 %32 CM Storm QuickFire Rapid O-ring: Large Keycap Installation, O-ring: Large Keycap: passo 1, imagem 3 %32
  2. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: passo 2, imagem 1 %32
    • Pull the large keycap upward with your fingers until the cap separates from the plastic rings underneath the cap. If the metal bar beneath the cap comes loose during removal, snap it back in place.
  3. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: passo 3, imagem 1 %32 CM Storm QuickFire Rapid O-ring: Large Keycap Installation: passo 3, imagem 2 %32 CM Storm QuickFire Rapid O-ring: Large Keycap Installation: passo 3, imagem 3 %32
    • Remove the plastic rings from the keycap.
  4. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: passo 4, imagem 1 %32 CM Storm QuickFire Rapid O-ring: Large Keycap Installation: passo 4, imagem 2 %32
    • Place the O-rings around the nubs underneath the keycap at each circled locations.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 6-23, Maness Fall 2014 Membro de Cal Poly, Team 6-23, Maness Fall 2014
CPSU-MANESS-F14S6G23
Membros da 4
Autoria de 12 guias
Um comentário
Best choice if you want all the “click” but none of the “clack” on your mechanical keyboard
Cherry Mx Black Rubber O-rings (125 pcs -EPDM – 40A) €3,98
Cherry Mx Black Rubber O-rings (90 pcs -EPDM – 40A) €3,48
[NL] O-rings Webstore http://tigri.bigcartel.com
Specs
Material: EPDM Industrial Grade Rubber
Color: Black
Hardness: 40A
Thickness: 1,50 mm (0.059 in)
Packaging: 125 pcs/bag or 90 pcs/bag
tigriorings - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 20
Duração total: 1,919
