Introdução
This device does not have any screws to open and change the internal HD. You will see the location and the types of plastic clippings holding the enclosure.
O que você precisa
The images you see are just of the enclosure. I have already removed the internal components. Its just to show the outside shape that will be opened to change the internal HD.
Three plastic hinges are on the top. Try and find them through the ventilation holes and push down with a thin objects. All other sides are held down so its will not come as open as seen in the picture. The images represent after all the sides are out. You will have to wedge something in there to keep on working on the other sides.
4 outras pessoas executaram este guia.
