Ir para o conteúdo principal
Brother XR-40 Lightbulb Replacement
O que você precisa
  1. Brother XR-40 Lightbulb Replacement, Back Panel: passo 1, imagem 1 %32
    • Place the machine on a solid surface.
    • Remove the 14mm Phillips #2 screw holding on the face cover.
    Pergunte ao FixBot
    Comentar
  2. Brother XR-40 Lightbulb Replacement: passo 2, imagem 1 %32
    • Remove the two 14mm Phillips #2 screws and two 22mm Phillips #2 screws that secure the rear casing.
    Pergunte ao FixBot
    Comentar
  3. Brother XR-40 Lightbulb Replacement: passo 3, imagem 1 %32
    • Lay the machine on its side.
    • Remove the four 10mm Phillips #2 screws that hold the bottom panel in place.
    • The feet will come off with the screws.
    Pergunte ao FixBot
    Comentar
  4. Brother XR-40 Lightbulb Replacement: passo 4, imagem 1 %32
    • Remove the bottom panel.
    Pergunte ao FixBot
    Comentar
  5. Brother XR-40 Lightbulb Replacement: passo 5, imagem 1 %32
    • Place the machine upright.
    • Remove the rear casing.
    • You may have to wiggle the panel and pull at the same time.
    Pergunte ao FixBot
    Comentar
  6. Brother XR-40 Lightbulb Replacement, Lightbulb: passo 6, imagem 1 %32
    • Using scissors, clip the two zip ties securing the lightbulb wire.
    Pergunte ao FixBot
    Comentar
  7. Brother XR-40 Lightbulb Replacement: passo 7, imagem 1 %32
    • Place the machine on its side, with access to the bottom.
    • Gently pull out the white wire connecting the bulb to the machine.
    Pergunte ao FixBot
    Comentar
  8. Brother XR-40 Lightbulb Replacement: passo 8, imagem 1 %32
    • Move the wire out from under the plastic hook.
    Pergunte ao FixBot
    Comentar
  9. Brother XR-40 Lightbulb Replacement: passo 9, imagem 1 %32
    • Using the flathead screwdriver, remove the 5mm Flathead screw holding on the lightbulb bracket.
    Pergunte ao FixBot
    Comentar
  10. Brother XR-40 Lightbulb Replacement: passo 10, imagem 1 %32
    • Remove the lightbulb assembly.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Kevin Bickers
Membro desde: 02/05/14
673 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 2-12, Amido Winter 2014 Membro de Cal Poly, Team 2-12, Amido Winter 2014
CPSU-AMIDO-W14S2G12
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 50
Ao todo: 3,777
