Ir para o conteúdo principal
Brother PT-D200 Faceplate Replacement
O que você precisa
    1. Brother PT-D200 Faceplate Replacement, Battery: passo 1, imagem 1 %32
      • Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
      Pergunte ao FixBot
      Comentar
    2. Brother PT-D200 Faceplate Replacement: passo 2, imagem 1 %32
      • Remove the six AAA batteries.
      Pergunte ao FixBot
      Comentar
    1. Brother PT-D200 Faceplate Replacement, Back of Device: passo 3, imagem 1 %32
      • Use the Helping Hand 1/4" screwdriver to unscrew the six 3/16" corner screws.
      Pergunte ao FixBot
      Comentar
    2. Brother PT-D200 Faceplate Replacement: passo 4, imagem 1 %32
      • Close the back cover and then flip the device over and separate the top half from the bottom half as shown.
      • Be gentle when lifting the top of the device, there is a ribbon cable attaching the two halves together.
      Pergunte ao FixBot
      Comentar
    1. Brother PT-D200 Faceplate Replacement, Circuit Board Cables: passo 5, imagem 1 %32
      • Gently pull out the ribbon cable from the circuit board.
      • The ribbon cable is very fragile.
      Pergunte ao FixBot
      Comentar
    2. Brother PT-D200 Faceplate Replacement: passo 6, imagem 1 %32
      • Remove two-pin plastic connector from the circuit board.
      • Gently pull the two-pin connector from the circuit board to avoid damaging the board.
      Pergunte ao FixBot
      Comentar
    1. Brother PT-D200 Faceplate Replacement, Face Plate: passo 7, imagem 1 %32
      • On the top portion of the device there are four grey clips locking the faceplate in place. The two top clips are circled in the image. The two others are located in the other corners of the device.
      Pergunte ao FixBot
      Comentar
    2. Brother PT-D200 Faceplate Replacement: passo 8, imagem 1 %32 Brother PT-D200 Faceplate Replacement: passo 8, imagem 2 %32
      • Pull the clips inward two at a time, first the top then the bottom, to snap the face plate off.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
[deleted]
Membro desde: 01/24/14
301 Reputação
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 36
Ao todo: 1,140
