Ir para o conteúdo principal
Brother PT-D200 Cutter Blade Replacement
    1. Brother PT-D200 Cutter Blade Replacement, Cutter Blade: passo 1, imagem 1 %32 Brother PT-D200 Cutter Blade Replacement, Cutter Blade: passo 1, imagem 2 %32
      • Open the back panel of the device by pressing down on and then pulling the indication arrows on the top center of the cover upward towards you.
      Pergunte ao FixBot
      Comentar
    2. Brother PT-D200 Cutter Blade Replacement: passo 2, imagem 1 %32
      • Locate the cutter blade unit (mint green) as shown in the picture.
      Pergunte ao FixBot
      Comentar
    3. Brother PT-D200 Cutter Blade Replacement: passo 3, imagem 1 %32 Brother PT-D200 Cutter Blade Replacement: passo 3, imagem 2 %32
      • Using the thumb and forefinger, pull up, applying a moderate amount of pressure until the cutter blade unit loosens and is removed.
      • The blade is sharp.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Cal Poly, Team 13-16, Regan Winter 2014 Membro de Cal Poly, Team 13-16, Regan Winter 2014
CPSU-REGAN-W14S13G16
3 Membros
Autoria de 30 guias
2Comentários do guia
Where can you order the replacement blade?
mistymeziere - Responder Compartilhar
Thank you it, the blade came out and I did not know how to fix this.. found this video and quickly fixed it..
niva - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 20
Últimos 30 dias: 88
Ao todo: 4,509
