Ir para o conteúdo principal
Brother IntelliFax-2840 Control Panel Replacement
O que você precisa
    1. Brother IntelliFax-2840 Control Panel Replacement, Automatic Document Feeder: passo 1, imagem 1 %32
      • Remove the two 15 mm Phillips #1 screws securing the ADF at the rear of the fax machine.
      Pergunte ao FixBot
      Comentar
    2. Brother IntelliFax-2840 Control Panel Replacement: passo 2, imagem 1 %32 Brother IntelliFax-2840 Control Panel Replacement: passo 2, imagem 2 %32
      • Gently pull the ADF up and away from the machine.
      Pergunte ao FixBot
      Comentar
    1. Brother IntelliFax-2840 Control Panel Replacement, Control Panel: passo 3, imagem 1 %32 Brother IntelliFax-2840 Control Panel Replacement, Control Panel: passo 3, imagem 2 %32
      • Gently lift up the control panel.
      Pergunte ao FixBot
      Comentar
    2. Brother IntelliFax-2840 Control Panel Replacement: passo 4, imagem 1 %32 Brother IntelliFax-2840 Control Panel Replacement: passo 4, imagem 2 %32 Brother IntelliFax-2840 Control Panel Replacement: passo 4, imagem 3 %32
      • Use a finger or prying tool to gently pop off the right side control arm (furthest from the handset).
      • Repeat for the left side control arm.
      • You can make this task easier by taking the handset out of the cradle and setting it aside.
      Pergunte ao FixBot
      Comentar
    3. Brother IntelliFax-2840 Control Panel Replacement: passo 5, imagem 1 %32 Brother IntelliFax-2840 Control Panel Replacement: passo 5, imagem 2 %32
      • Do not attempt to completely remove the control panel yet, as it is still connected by a cable.
      • Lifting from the front edge, gently flip up the control panel.
      Pergunte ao FixBot
      Comentar
    4. Brother IntelliFax-2840 Control Panel Replacement: passo 6, imagem 1 %32
      • While supporting the control panel with one hand, remove the three 12.2 mm Phillips #1 screws securing the rear control panel cover.
      Pergunte ao FixBot
      Comentar
    5. Brother IntelliFax-2840 Control Panel Replacement: passo 7, imagem 1 %32
      • While still supporting the control panel, use your fingers or a spudger to gently free the two plastic clips securing the rear control panel cover.
      • Slide the rear control panel cover down slightly to free it from the three clips along the upper edge.
      Pergunte ao FixBot
      Comentar
    6. Brother IntelliFax-2840 Control Panel Replacement: passo 8, imagem 1 %32 Brother IntelliFax-2840 Control Panel Replacement: passo 8, imagem 2 %32
      • Separate the rear control panel cover from the control panel.
      Pergunte ao FixBot
      Comentar
    7. Brother IntelliFax-2840 Control Panel Replacement: passo 9, imagem 1 %32 Brother IntelliFax-2840 Control Panel Replacement: passo 9, imagem 2 %32
      • Gently pull the control panel cable straight out from its connector.
      • The control panel should now come free.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Geoff Wacker
Membro desde: 09/30/13
92.899 Reputação
Autoria de 89 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 23
Ao todo: 4,611
