Introdução
Use this guide to remove the front speaker panel in your device. You’ll need to know how to solder to fully replace the speaker panel in your Braven BRV-X. The How to Solder and Desolder Connections guide may help you with this guide.
O que você precisa
Remove four 1.1 cm outer screws in the outer shell using the Phillips #00 screwdriver.
Quase terminado!
Conclusão
