Ir para o conteúdo principal
Braven BRV-X Button Module(s) Replacement
O que você precisa
  1. Braven BRV-X Button Module(s) Replacement, Front Speaker Panel: passo 1, imagem 1 %32
    • Remove four 1.1 cm outer screws in the outer shell using the Phillips #00 screwdriver.
  2. Braven BRV-X Button Module(s) Replacement: passo 2, imagem 1 %32
    • Remove four 1.3 cm inner screws in the outer shell using the 1.5mm Hex screwdriver.
  3. Braven BRV-X Button Module(s) Replacement: passo 3, imagem 1 %32
    • Gently remove the outer shell.
  4. Braven BRV-X Button Module(s) Replacement: passo 4, imagem 1 %32 Braven BRV-X Button Module(s) Replacement: passo 4, imagem 2 %32
    • Cut adhesive tape on both sides.
  5. Braven BRV-X Button Module(s) Replacement: passo 5, imagem 1 %32 Braven BRV-X Button Module(s) Replacement: passo 5, imagem 2 %32
    • Remove eighteen 0.9cm screws in the inner shell using the Phillips #00 screwdriver.
  6. Braven BRV-X Button Module(s) Replacement: passo 6, imagem 1 %32 Braven BRV-X Button Module(s) Replacement: passo 6, imagem 2 %32 Braven BRV-X Button Module(s) Replacement: passo 6, imagem 3 %32
    • Pry open the glued inner shell using a spudger around all sides of the shell.
    • Don't use too much pressure as that could cause damage to the plastic.
  7. Braven BRV-X Button Module(s) Replacement: passo 7, imagem 1 %32 Braven BRV-X Button Module(s) Replacement: passo 7, imagem 2 %32
    • Remove ten 0.7 cm screws in the front plate using the 1.5 mm Hex screwdriver.
  8. Braven BRV-X Button Module(s) Replacement: passo 8, imagem 1 %32 Braven BRV-X Button Module(s) Replacement: passo 8, imagem 2 %32
    • Use a spudger to open the front speaker plate.
  9. Braven BRV-X Button Module(s) Replacement: passo 9, imagem 1 %32
    • Remove three 1.0 cm screws from the battery unit.
    • It is recommended (but not required) to remove the battery.
  10. Braven BRV-X Button Module(s) Replacement: passo 10, imagem 1 %32 Braven BRV-X Button Module(s) Replacement: passo 10, imagem 2 %32
    • Disconnect the ribbon cable attached the main board.
  11. Braven BRV-X Button Module(s) Replacement: passo 11, imagem 1 %32 Braven BRV-X Button Module(s) Replacement: passo 11, imagem 2 %32 Braven BRV-X Button Module(s) Replacement: passo 11, imagem 3 %32
    • Pry open the second plate holding in the speaker using a spudger around all sides.
    • It is recommended to use a spudger to remove the heavily glued areas between the plates before prying.
  12. Braven BRV-X Button Module(s) Replacement: passo 12, imagem 1 %32 Braven BRV-X Button Module(s) Replacement: passo 12, imagem 2 %32 Braven BRV-X Button Module(s) Replacement: passo 12, imagem 3 %32
    • Cut the 20 gauge wires attached to the front IR sensor and two speaker wires.
    • Leave enough length on the wire to work with it afterwards.
    • Cut the 22 gauge wire attached in the corner.
    • Solder the new speaker plate during reassembly.
    • To properly solder and desolder connections, visit the How to Solder and Desolder Connections guide.
  13. Braven BRV-X Button Module(s) Replacement, Button Module(s): passo 13, imagem 1 %32 Braven BRV-X Button Module(s) Replacement, Button Module(s): passo 13, imagem 2 %32
    • Remove the ribbon cable attached to the main board.
    • Pull from the clip and not from the cable.
  14. Braven BRV-X Button Module(s) Replacement: passo 14, imagem 1 %32
    • Remove three 0.7 cm screws from the button module(s) using the Phillips #00 screwdriver.
  15. Braven BRV-X Button Module(s) Replacement: passo 15, imagem 1 %32
    • Gently lift the button module from the enclosure.
Conclusão
Trey Peterson
Membro desde: 04/01/19
301 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G5, Harley Spring 2019 Membro de IUPUI, Team S1-G5, Harley Spring 2019
IUPUI-HARLEY-S19S1G5
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 398
