Ir para o conteúdo principal
Braun Shaver Model 7680 Battery Replacement
O que você precisa
  1. Braun Shaver Model 7680 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Soldering is required to install this battery one or two batteries may be required verify how many you need before you order
    Pergunte ao FixBot
    Comentar
  2. Braun Shaver Model 7680 Battery Replacement, Remove bottom cover: passo 2, imagem 1 %32 Braun Shaver Model 7680 Battery Replacement, Remove bottom cover: passo 2, imagem 2 %32
    • First pry the left side of the cover off, then pry the right side of the cover off before removing. Trying to pry the cover off from only one side will result in breaking the plastic tabs.
    Pergunte ao FixBot
    Comentar
  3. Braun Shaver Model 7680 Battery Replacement, Remove side covers: passo 3, imagem 1 %32
    • Pull the side covers off from the bottom, they hinge from the top and will come off freely once you rotate them up and away from the body starting at the bottom.
    Pergunte ao FixBot
    Comentar
  4. Braun Shaver Model 7680 Battery Replacement, Remove screws on back: passo 4, imagem 1 %32 Braun Shaver Model 7680 Battery Replacement, Remove screws on back: passo 4, imagem 2 %32
    • You will need a T9 hex screw driver.
    Pergunte ao FixBot
    Comentar
    • R17 AA NiMh Battery With Pin Tabs 1650 Mah 1.2V Battery Measures .559" x 1.97", 14.2mm x 50mm
    Pergunte ao FixBot
    Comentar
    • Replacing the batteries will not always repair the shaver, the circuit board may be bad, if the indicator lights on the circuit board do not light up when plugged in the circuit board is most likely bad, you should replace the entire circuit board and battery assembly.
    Pergunte ao FixBot
    Comentar
Conclusão
19 outras pessoas executaram este guia.
mayer
Membro desde: 01/04/10
690.411 Reputação
Autoria de 11 guias
8Comentários do guia
Great tutorial. It was all I needed, since I wasn't sure how to get the case open. Thanks!
mikebailey - Responder Compartilhar
Thanks for the tutorial! Mine had intermittent problem with the on/off switch and I was googling how to open the case. Easy and simple, bets razor I’ve had and not willing to change :D
Tero Kortetmäki - Responder Compartilhar
Thanks for the tutorial… but it is a T8 Torx at least in the Model 7570. I just had to take out the recharchable batteries to get mine working properly again.
A Krueger - Responder Compartilhar
Danke für die übersichtliche Anleitung, hat mir gut geholfen. Die wichtige Frage ist immer:
Wie geht ‘s Gehäuse auf. ?
Garofalo - Responder Compartilhar
Thanks for the guide! Without knowing how to open the case, replacing the battery would have been a lost cause. In my case the batteries were tired. After replacing and recharging them the razor sounds young again and full of pep.
Stephen Spratley - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 21
Últimos 30 dias: 147
Ao todo: 25,151
