Ir para o conteúdo principal
Braun Oral-B Sonic Complete 4729 Battery Replacement
O que você precisa
  1. Braun Oral-B Sonic Complete 4729 Battery Replacement, Opening the bottom lid: passo 1, imagem 1 %32 Braun Oral-B Sonic Complete 4729 Battery Replacement, Opening the bottom lid: passo 1, imagem 2 %32 Braun Oral-B Sonic Complete 4729 Battery Replacement, Opening the bottom lid: passo 1, imagem 3 %32
    • Take the device and place it on top of its charger.
    • Now hold down firmly the charger and pull the top of the toothbrush backwards.
    • Just above the lid there is the induction coil, so don't pull too much, or it could get damaged!
    • When the lid at the bottom opens, stop pulling and take it off manually
  2. Braun Oral-B Sonic Complete 4729 Battery Replacement, Pull of the water protection ring: passo 2, imagem 1 %32 Braun Oral-B Sonic Complete 4729 Battery Replacement, Pull of the water protection ring: passo 2, imagem 2 %32 Braun Oral-B Sonic Complete 4729 Battery Replacement, Pull of the water protection ring: passo 2, imagem 3 %32
    • Take the screwdriver (or the plastic opening tool) and go under the ring at the top of the gummed area.
    • Now rotate it slightly so the ring comes loose.
    • Be careful not to damage the gum under the ring, as it assures that no water gets inside!
  3. Braun Oral-B Sonic Complete 4729 Battery Replacement, Take out the interior: passo 3, imagem 1 %32 Braun Oral-B Sonic Complete 4729 Battery Replacement, Take out the interior: passo 3, imagem 2 %32 Braun Oral-B Sonic Complete 4729 Battery Replacement, Take out the interior: passo 3, imagem 3 %32
    • Push the point of the device down onto the table and take out the inside.
  4. Braun Oral-B Sonic Complete 4729 Battery Replacement, Clearing the way for the battery (Part 1): passo 4, imagem 1 %32 Braun Oral-B Sonic Complete 4729 Battery Replacement, Clearing the way for the battery (Part 1): passo 4, imagem 2 %32 Braun Oral-B Sonic Complete 4729 Battery Replacement, Clearing the way for the battery (Part 1): passo 4, imagem 3 %32
    • First take away the metal sheet of the start/stop button.
    • Then pull the center of the black metal connection of the pressure sensor slightly upwards until the hook holding it to the sensor comes loose.
    • Now it has to be desoldered from the logic board.
  5. Braun Oral-B Sonic Complete 4729 Battery Replacement, Clearing the way for the battery (Part 2): passo 5, imagem 1 %32 Braun Oral-B Sonic Complete 4729 Battery Replacement, Clearing the way for the battery (Part 2): passo 5, imagem 2 %32 Braun Oral-B Sonic Complete 4729 Battery Replacement, Clearing the way for the battery (Part 2): passo 5, imagem 3 %32
    • Now you have to desolder the sensor connection and both the connections to the red led at the top.
    • The white plastic pins left and right to the led connections can easily melt!
    • Then desolder the connections to the charging coil.
    • Be careful not to touch nearby electronic components, as they could get damaged!
    • And keep the soldering time short and remove the soldering iron as soon as the solder has become liquid, so there is no overheating risk!
  6. Braun Oral-B Sonic Complete 4729 Battery Replacement, Clearing the way for the battery (Part 3): passo 6, imagem 1 %32 Braun Oral-B Sonic Complete 4729 Battery Replacement, Clearing the way for the battery (Part 3): passo 6, imagem 2 %32 Braun Oral-B Sonic Complete 4729 Battery Replacement, Clearing the way for the battery (Part 3): passo 6, imagem 3 %32
    • First pull off the white plastic support for the red led.
    • Then push the plastic casing of the battery together to pull of the coil.
  7. Braun Oral-B Sonic Complete 4729 Battery Replacement, Clearing the way for the battery (Part 3): passo 7, imagem 1 %32
    • Now the connections to the motor have to be desoldered to take the battery casing of.
Conclusão
5 outras pessoas executaram este guia.
TheFixaholic
Membro desde: 04/27/15
600 Reputação
Autoria de 3 guias
2 comentários
A good guide but I found removing the bottom quite troublesome. Levering against the charging base felt like it would break the base. I needed to lever it in stages, wedge it and grab and pull it with mole grips. This damaged the plastic a little, but I got it off.
Cone - Responder
Hmm, maybe they changed the construction. When I created the guide the bottoms (of the 2 toothbrushes I repaired) opened quite easily, but that's good to know.
Also I do not think you need to worry about breaking the base: as most chargers that you plug in the mains, it should be completely filled with a hard resin, and thus be almost indestructible.
TheFixaholic -
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 107
Ao todo: 8,517
