Ir para o conteúdo principal
Braun KMM1 Coffe Grinder Disassembly for cleaning
O que você precisa
  1. Braun KMM1 Coffe Grinder Disassembly for cleaning, Braun KMM1 Coffe Grinder Disassembly for cleaning: passo 1, imagem 1 %32
    • First, remove the coffee powder container
  2. Braun KMM1 Coffe Grinder Disassembly for cleaning: passo 2, imagem 1 %32
    • Remove the cap of the bean container
  3. Braun KMM1 Coffe Grinder Disassembly for cleaning: passo 3, imagem 1 %32 Braun KMM1 Coffe Grinder Disassembly for cleaning: passo 3, imagem 2 %32
    • Now it's time to rotate the bean container anti-clockwise to remove it from the machine
    Hallo, habe gerad ein Exemplar bei Kleinanzeigen ergattert, allerdings kann ich den oberen Teil gar nicht drehen. Weder um den mahlgrad einzustellen, noch um das Ding abzunehmen. Gibt es einen Trick oder liegt es vielleicht am Schmutz? Freue mich über Anregungen
    Tina Keller - Responder
  4. Braun KMM1 Coffe Grinder Disassembly for cleaning: passo 4, imagem 1 %32
    • Here you can see the mill wheel which is now ready to be cleaned
    How do I disassemble this grinder?
    halka319 - Responder
    It is difficult to rotate anti-clockwise to dismantle. Please suggest some easy method to unscrew the top from the body. Thanks
    Nagarajan - Responder
    I’m not convinced the grinder comes apart. I held it while unscrewing the three flat head screws but it didn’t come apart. Maybe I should have tried for longer, but I suspect it is a sealed unit since on the bottom there is the round base base of it with the two peg holes. On mine the plastic is also fused to seal it at factory I suppose.
    Gordon Jackson - Responder
  5. Braun KMM1 Coffe Grinder Disassembly for cleaning: passo 5, imagem 1 %32 Braun KMM1 Coffe Grinder Disassembly for cleaning: passo 5, imagem 2 %32 Braun KMM1 Coffe Grinder Disassembly for cleaning: passo 5, imagem 3 %32
    • Back to the bean container!
    • After a short cleaning action you should be able to loosen this three Philips screws
  6. Braun KMM1 Coffe Grinder Disassembly for cleaning: passo 6, imagem 1 %32 Braun KMM1 Coffe Grinder Disassembly for cleaning: passo 6, imagem 2 %32
    • Now the bean container is completely disassembled and ready for some cleaning work!
Conclusão
17 outras pessoas executaram este guia.
Daniel
Membro desde: 07/06/15
961 Reputação
Autoria de 2 guias
Equipe
iFixit EU Team Membro de iFixit EU Team
Staff
39 Membros
Autoria de 1.137 guias
9 comentários
Hi Daniel,
Thanks for the tutorial.
Would you have, by any chance, the usermanual of the grinder?
I’m wondering to what grinding size the numbering is corresponding to.
Many thanks! :)
Best regards,
Greg
freestyle_on_the_moon - Responder
I have this same issue! Did you ever find out? Im guessing that the grind size of the KMM1 is the same as the KMM20? So left (where it says mocca)for finest grind, right for the largest grind?
Will Clempson -
Umm.. My bottom burr doesn’t seem to have screws and look like rivits. maybe previous owner stripped the screws :(
Zarni Ko - Responder
Mine has something like rivets as well. I used toothpicks and cotton swabs to clean as much as I could,, then had some luck running dried couscous through the grinder. Softer than rice and seemed to pick up the last bits of residue.
Zeke Kossover -
Gilt diese Anleitung zur Reinigung auch für die Braun Kaffeemühle 4045?
Karl-Heinz Kaufmann - Responder
Könnte sein. Das Gerät heißt KMM 20 Typ 4045, vermutlich eine Weiterentwicklung der KMM 1.
VauWeh -
My grinder is stuck on course how to I “clean it” recalibrate it?
Thanks
bonnienewman - Responder
Hi Daniel,
do you know by chance what size the burrs are? I was wodnering if I could upgrade my Braun with new and modern Burrs that maybe create less fines
Best
vizzzo - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 48
Últimos 30 dias: 164
Ao todo: 12,270
