Introdução
When an electric trimmer stops working, your first thought might be it is because there is something wrong with the charger or that you have damaged the power connector in the trimmer, as so I thought. However, it is usually the case that the battery is worn out.
So, get ready to invest your time and money on a Soldering kit and other listed tools and follow this guide. The guide specifically shows you how you can replace your Braun BT3240 Electric Trimmer's batteries which would require you to have soldering skills. Click here to develop/refine your soldering skills.
For replacement parts or further assistance, visit Contact us.
O que você precisa
Ensure that the positive and negative electrodes are correctly identified and now place the new batteries onto the battery holder.
Apply Soldering paste on the battery contact tab and then melt solder alloy on to the tip of the soldering iron and touch the tip of the soldering iron to one of the 4 specified battery contact tab. Repeat this same step for the other 3 battery contact tabs. Apply some more soldering iron alloy if the batteries do not feel rigid on the holder.
Once the solder on each side has dried out and in cool temperature, you can reassemble the parts and test the trimmer’s functionality.
To check if the trimmer works perfectly, you need to notice the head of the trimmer. The head of the trimmer should be rotating clockwise when you press the power button.
