Ir para o conteúdo principal
Bottom Plate Removal
O que você precisa
  1. Bottom Plate Removal, Remove back cover: passo 1, imagem 1 %32
    • Push down on the screw to depress the spring loaded hinge and release the door.
    Pergunte ao FixBot
    Comentar
  2. Bottom Plate Removal, Remove bottom cover: passo 2, imagem 1 %32
    • Remove six 5.3 mm #00 screws.
    • Remove one 3.4 mm #00 screw.
    • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
    Pergunte ao FixBot
    Comentar
  3. Bottom Plate Removal, Remove left front cover: passo 3, imagem 1 %32
    • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
    • Remove one 7.3 mm #00 screw.
    • Remove the remote trigger cover.
    Pergunte ao FixBot
    Comentar
  4. Bottom Plate Removal, Remove front cover: passo 4, imagem 1 %32 Bottom Plate Removal, Remove front cover: passo 4, imagem 2 %32
    • Remove two 5.3 mm #00 screw.
    • Gently lift up on the flash housing to help remove the cover if necessary.
    Pergunte ao FixBot
    Comentar
  5. Bottom Plate Removal, Remove right front cover: passo 5, imagem 1 %32
    • Remove two 3.9 mm #00 screws.
    Pergunte ao FixBot
    Comentar
  6. Bottom Plate Removal, Prepare bottom plate: passo 6, imagem 1 %32 Bottom Plate Removal, Prepare bottom plate: passo 6, imagem 2 %32
    • Remove two 3.4 mm #00 screws. Remove the plate holding the contacts in place.
    • Peel tape from the plate. Leave the tape attached to the flex circuit.
    • Remove the flex circuits from their retaining studs.
    Pergunte ao FixBot
    Comentar
  7. Bottom Plate Removal, Remove bottom plate: passo 7, imagem 1 %32 Bottom Plate Removal, Remove bottom plate: passo 7, imagem 2 %32
    • Remove one 3.3 mm #0 countersunk screw.
    • Remove one 3.9 mm #0 shoulder screw.
    • Remove four 3.3 mm #00 screws.
    • Pull a little slack through the housing on this flex cable.
    • Pop the plate off its posts, rotate slightly clockwise and pull gently through the loosened flex cable.
    • To the camera tech that left me a happy little note...I see you.
    Pergunte ao FixBot
    Comentar
  8. Bottom Plate Removal, Remove transport gears: passo 8, imagem 1 %32 Bottom Plate Removal, Remove transport gears: passo 8, imagem 2 %32
    • It's best to remove these parts now so they don't fall out later on in the repair.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Sam Gustafson
Membro desde: 09/01/22
13.004 Reputação
Autoria de 78 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 44
Ao todo: 898
