Ir para o conteúdo principal
Bose Soundlink Revolve Top Circuit Board Replacement
O que você precisa
  1. Bose Soundlink Revolve Top Circuit Board Replacement, Bottom Circuit Board Access: passo 1, imagem 1 %32 Bose Soundlink Revolve Top Circuit Board Replacement, Bottom Circuit Board Access: passo 1, imagem 2 %32
    • Flip speaker over so that the bottom is facing up.
    • Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
    Pergunte ao FixBot
    Comentar
  2. Bose Soundlink Revolve Top Circuit Board Replacement: passo 2, imagem 1 %32 Bose Soundlink Revolve Top Circuit Board Replacement: passo 2, imagem 2 %32 Bose Soundlink Revolve Top Circuit Board Replacement: passo 2, imagem 3 %32
    • Using the screwdriver, unscrew three screws.
    • Detach the bottom cover from the rest of the speaker by pulling the two in opposite directions.
    Pergunte ao FixBot
    Comentar
  3. Bose Soundlink Revolve Top Circuit Board Replacement: passo 3, imagem 1 %32 Bose Soundlink Revolve Top Circuit Board Replacement: passo 3, imagem 2 %32
    • Remove the screw that is above the charging port.
    Pergunte ao FixBot
    Comentar
  4. Bose Soundlink Revolve Top Circuit Board Replacement: passo 4, imagem 1 %32 Bose Soundlink Revolve Top Circuit Board Replacement: passo 4, imagem 2 %32
    • Remove the two screws connecting the motherboard to the bottom cover of the speaker.
    • Remove the bottom cover.
    Pergunte ao FixBot
    Comentar
  5. Bose Soundlink Revolve Top Circuit Board Replacement, Top Circuit Board: passo 5, imagem 1 %32
    • Using your hands, grip and separate the soft plastic and the metal casing away from each other with some small force.
    Pergunte ao FixBot
    Comentar
  6. Bose Soundlink Revolve Top Circuit Board Replacement: passo 6, imagem 1 %32
    • Remove the (4) four screws shown around the top of the inside.
    • (2) two of the screws are shown here, the other side will look the same.
    Pergunte ao FixBot
    Comentar
  7. Bose Soundlink Revolve Top Circuit Board Replacement: passo 7, imagem 1 %32 Bose Soundlink Revolve Top Circuit Board Replacement: passo 7, imagem 2 %32
    • Pry up and remove the soft plastic casing from the rest of the device.
    Pergunte ao FixBot
    Comentar
  8. Bose Soundlink Revolve Top Circuit Board Replacement: passo 8, imagem 1 %32 Bose Soundlink Revolve Top Circuit Board Replacement: passo 8, imagem 2 %32
    • Remove the 3 screws holding down the top circuit board.
    Pergunte ao FixBot
    Comentar
  9. Bose Soundlink Revolve Top Circuit Board Replacement: passo 9, imagem 1 %32
    • Lift up and look on the underside of the circuit board.
    • Using the plastic opening tool, pry open the wide clamp keeping a ribbon to the top circuit board. The top circuit board can now freely be removed from the device.
    Pergunte ao FixBot
    Comentar
Conclusão
13 outras pessoas executaram este guia.
Brian Butner
Membro desde: 09/27/17
927 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S6-G2, Remmell Fall 2017 Membro de USF Tampa, Team S6-G2, Remmell Fall 2017
USFT-REMMELL-F17S6G2
4 Membros
Autoria de 4 guias
13Comentários do guia
Hello,
I need to buy the TOP CIRCUIT BOARD … Where Can I buy it or could you sell me one ? Thank you my mail is skelet300@gmail.com
skelet300 - Responder Compartilhar
I also need one of these boards and don’t really want to buy a complete used unit to repair mine, copydoc1@aol.com if you know of any resources, thanks in advance.
Jeff Pitt - Responder Compartilhar
Same here. My speaker had one circuit replacement on warranty but now need a second replacement and I not willing to pay half the price of a new speaker each a every year. Can you help please ?
My e-mail is fmtbmp@gmail.com
fmpitschieller - Responder Compartilhar
Hi, I need to buy the top and bottom circuit board and was wondering the same. Any help with where to purchase these would be appreciated,
Thanks, my email is fayclaybrook28@outlook.com
Fay Claybrook - Responder Compartilhar
I am also looking for a top circuit board replacement. Where can I get one. michael@parsche.net
Michael Parsche - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 80
Ao todo: 15,639
