Ir para o conteúdo principal
Bose Soundlink Flex Radiator Replacement
O que você precisa
  1. Bose Soundlink Flex Radiator Replacement, Grille: passo 1, imagem 1 %32
    • Use a heat gun to warm up the device.
    • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
    Pergunte ao FixBot
    Comentar
  2. Bose Soundlink Flex Radiator Replacement: passo 2, imagem 1 %32
    • Use an iFixit opening tool to pop off the eight clips on the grille.
    • Be patient and do not rush this process as you may otherwise damage the device.
    Pergunte ao FixBot
    Comentar
  3. Bose Soundlink Flex Radiator Replacement: passo 3, imagem 1 %32 Bose Soundlink Flex Radiator Replacement: passo 3, imagem 2 %32
    • Once the clips have been released, the only thing holding the grille on is glue.
    • Apply minimal force and the grille should pop right off the device.
    • Reheat the device to warm up the glue if there is difficulty in removing.
    Pergunte ao FixBot
    Comentar
  4. Bose Soundlink Flex Radiator Replacement, Radiator: passo 4, imagem 1 %32 Bose Soundlink Flex Radiator Replacement, Radiator: passo 4, imagem 2 %32 Bose Soundlink Flex Radiator Replacement, Radiator: passo 4, imagem 3 %32
    • Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
    • Lift the driver out, being cautious of the wires still connected to the device.
    Pergunte ao FixBot
    Comentar
  5. Bose Soundlink Flex Radiator Replacement: passo 5, imagem 1 %32 Bose Soundlink Flex Radiator Replacement: passo 5, imagem 2 %32
    • Remove the six 2.3 mm screws around the edge with a TR8 Torx screwdriver.
    Pergunte ao FixBot
    Comentar
  6. Bose Soundlink Flex Radiator Replacement: passo 6, imagem 1 %32 Bose Soundlink Flex Radiator Replacement: passo 6, imagem 2 %32 Bose Soundlink Flex Radiator Replacement: passo 6, imagem 3 %32
    • Pull the backplate off to expose both sides of the radiator.
    Pergunte ao FixBot
    Comentar
  7. Bose Soundlink Flex Radiator Replacement: passo 7, imagem 1 %32 Bose Soundlink Flex Radiator Replacement: passo 7, imagem 2 %32 Bose Soundlink Flex Radiator Replacement: passo 7, imagem 3 %32
    • Remove the four 2.3 mm corner screws using a TR8 Torx screwdriver.
    • Remove the two 1.7 mm screws using a TR6 Torx screwdriver.
    • Follow this step for both radiators.
    Pergunte ao FixBot
    Comentar
  8. Bose Soundlink Flex Radiator Replacement: passo 8, imagem 1 %32 Bose Soundlink Flex Radiator Replacement: passo 8, imagem 2 %32
    • Remove the radiator and replace with the new radiator.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Monica Silva
Membro desde: 03/19/24
262 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 48
Ao todo: 963
