Ir para o conteúdo principal
Bose Soundlink Flex Battery Replacement
O que você precisa
  1. Bose Soundlink Flex Battery Replacement, Grille: passo 1, imagem 1 %32
    • Use a heat gun to warm up the device.
    • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
    Pergunte ao FixBot
    Comentar
  2. Bose Soundlink Flex Battery Replacement: passo 2, imagem 1 %32
    • Use an iFixit opening tool to pop off the eight clips on the grille.
    • Be patient and do not rush this process as you may otherwise damage the device.
    Pergunte ao FixBot
    Comentar
  3. Bose Soundlink Flex Battery Replacement: passo 3, imagem 1 %32 Bose Soundlink Flex Battery Replacement: passo 3, imagem 2 %32
    • Once the clips have been released, the only thing holding the grille on is glue.
    • Apply minimal force and the grille should pop right off the device.
    • Reheat the device to warm up the glue if there is difficulty in removing.
    Pergunte ao FixBot
    Comentar
  4. Bose Soundlink Flex Battery Replacement, Battery: passo 4, imagem 1 %32 Bose Soundlink Flex Battery Replacement, Battery: passo 4, imagem 2 %32 Bose Soundlink Flex Battery Replacement, Battery: passo 4, imagem 3 %32
    • Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
    • Lift the driver out, being cautious of the wires still connected to the device.
    Pergunte ao FixBot
    Comentar
  5. Bose Soundlink Flex Battery Replacement: passo 5, imagem 1 %32 Bose Soundlink Flex Battery Replacement: passo 5, imagem 2 %32 Bose Soundlink Flex Battery Replacement: passo 5, imagem 3 %32
    • Remove the six 2.3 mm screws around the edge with a TR8 Torx screwdriver.
    • Pull the back panel off exposing the motherboard.
    Pergunte ao FixBot
    Comentar
  6. Bose Soundlink Flex Battery Replacement: passo 6, imagem 1 %32 Bose Soundlink Flex Battery Replacement: passo 6, imagem 2 %32
    • Remove the three 1.7 mm screws from the motherboard using a TR6 Torx screwdriver.
    • Remove the single 1.4 mm screw from the motherboard using a TR5 Torx screwdriver.
    Pergunte ao FixBot
    Comentar
  7. Bose Soundlink Flex Battery Replacement: passo 7, imagem 1 %32 Bose Soundlink Flex Battery Replacement: passo 7, imagem 2 %32 Bose Soundlink Flex Battery Replacement: passo 7, imagem 3 %32
    • Take the motherboard out and take note of the battery attached.
    • Remove the insulation and the solder from the wiring.
    • Be careful not to damage the motherboard. Doing so will create a slew of problems for the speaker.
    • Solder the wires of the new battery onto the motherboard.
    • Be cautious when adding the solder to not damage the motherboard or burn yourself.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Kalvin Lee
Membro desde: 03/19/24
625 Reputação
Autoria de 3 guias
Equipe
1Comentário do guia
How do I know which one is the positive and which one is the negative side of my battery connector in soundlink flex ? As I have already removed the old battery only.
SOM SATPATHY - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 19
Últimos 7 dias: 98
Últimos 30 dias: 439
Ao todo: 8,248
