Ir para o conteúdo principal
Bose SoundLink Mini II Battery Replacement
O que você precisa
  1. Bose SoundLink Mini II Battery  Replacement, Battery: passo 1, imagem 1 %32 Bose SoundLink Mini II Battery  Replacement, Battery: passo 1, imagem 2 %32
    • Flip the speaker over onto its back.
  2. Bose SoundLink Mini II Battery  Replacement, Remove the rubber base: passo 2, imagem 1 %32 Bose SoundLink Mini II Battery  Replacement, Remove the rubber base: passo 2, imagem 2 %32
    • Gently remove the rubber base from speaker by pulling around the edges.
  3. Bose SoundLink Mini II Battery  Replacement: passo 3, imagem 1 %32 Bose SoundLink Mini II Battery  Replacement: passo 3, imagem 2 %32
    • Remove the four 6mm T9 Torx bit screws from the corners of the battery.
  4. Bose SoundLink Mini II Battery  Replacement: passo 4, imagem 1 %32 Bose SoundLink Mini II Battery  Replacement: passo 4, imagem 2 %32 Bose SoundLink Mini II Battery  Replacement: passo 4, imagem 3 %32
    • Carefully lift the battery from the side nearest the four gold contact pins, but don't try to fully remove it yet.
    • At this point, the battery remains connected via four wires to the power supply board.
    • Carefully desolder the four wires from the power supply board in order to completely detach the battery. There is very little room for the soldering iron without damaging the case or the board; you may want to remove the board first.
    • For help with soldering, see the soldering guide.
    • Alternatively, you may remove the battery and power supply board together, without any soldering, but access requires some additional disassembly while carefully leaving the battery connected via the wires the entire time.
  5. Bose SoundLink Mini II Battery  Replacement, Bose Technicians' Instruction Manual: passo 5, imagem 1 %32
Conclusão
44 outras pessoas executaram este guia.
Devon
Membro desde: 02/15/17
542 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 5-2, Passmore Spring 2017 Membro de USF Tampa, Team 5-2, Passmore Spring 2017
USFT-PASSMORE-S17S5G2
4 Membros
Autoria de 19 guias
49Comentários do guia
3 Contributors and none of them know how to remove the battery, brilliant... Honestly if you want to do this right, do it right from the begining. The battery is connected with a cable to the device, please explain how did you remove it properly.
Timo Bernhard - Responder
Hey Timo,
no, there are just two different battery versions of the Soundlink Mini 2: One without a cable from the battery to the PCB (as shown in this tutorial, i think this is the older version of the Soundlink Mini2) and one with a cable...
I have one here with a cable and I?m desperate to find a new battery for it but can`t find it anywhere on the net... I`m thinking of trying a battery without the cables and try to connect four cables to the battery and then solder them to the PCB...
Christoph Jeschke -
But how do I disconnect the battery having a cable?! - That’s actually the hard part.
Thomas Amsler - Responder
You will have to take out the mesh on front and back. Then take out screws on speakerssside. The smalle print can be taken out then and you have to solder the battery. Just done this, and not a easy job.
Onno -
If you have the Soundlink  Mini 2, you can send the battery to Bose and they will rebuild it for $75. It is not user replaceable, although if you are electronics savvy you can remove it.
Problem is there are no replacements out there, and these batteries have a control board soldered to the battery with a ribbon cable. This will require soldering and unsoldering if there was a battery replacement for it. This also requires taking the entire Soundlink Mini 2 speaker apart to remove the board and battery.
If you send the battery to Bose expect a 3 to 6 week turn around for a return, which includes about 10 business days of shipping both ways as its a Lithium battery and can only travel ground. Plus the $75 for the repair as mentioned earlier.
They really did a wonderful job in limiting your options on this item.
Bose Hold this L for us as in Losers!
Bronx - Responder
Comentar
Visualizações:
Últimas 24 horas: 42
Últimos 7 dias: 438
Últimos 30 dias: 1,994
Ao todo: 238,471
