Ir para o conteúdo principal
Bose SoundLink Mini Button Switch Circuit Board Replacement
O que você precisa
  1. Bose SoundLink Mini Button Switch Circuit Board Replacement, Battery: passo 1, imagem 1 %32
    • Peel back the rubber battery cover and remove the four circled 6.0 mm screws using a T8 Torx Screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 2, imagem 1 %32 Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 2, imagem 2 %32
    • While holding the cover back, pull straight up on the battery to remove it.
    Pergunte ao FixBot
    Comentar
  3. Bose SoundLink Mini Button Switch Circuit Board Replacement, Front/Back Protective Grille: passo 3, imagem 1 %32
    • Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
    • Place Metal Spudger in the location shown.
    Pergunte ao FixBot
    Comentar
  4. Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 4, imagem 1 %32 Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 4, imagem 2 %32
    • Slowly pry up the grille until the two tabs shown pop out.
    • Be very gentle, the grille will bend.
    Pergunte ao FixBot
    Comentar
  5. Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 5, imagem 1 %32 Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 5, imagem 2 %32
    • The grille is attached to the speaker with double sided sticky tape. To remove the grill gently pull upward while keeping tension to the right.
    Pergunte ao FixBot
    Comentar
  6. Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 6, imagem 1 %32 Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 6, imagem 2 %32
    • Repeat steps to remove the back grille.
    Pergunte ao FixBot
    Comentar
  7. Bose SoundLink Mini Button Switch Circuit Board Replacement, Battery Cover: passo 7, imagem 1 %32 Bose SoundLink Mini Button Switch Circuit Board Replacement, Battery Cover: passo 7, imagem 2 %32
    • Remove the four 15.0 mm screws on the left and the four 9.0 mm screws on the right using the T8 Torx Screwdriver.
    Pergunte ao FixBot
    Comentar
  8. Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 8, imagem 1 %32 Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 8, imagem 2 %32
    • Remove the circuit board by pushing it with your index finger in the direction shown while using a nylon or metal spudger to lift it up and out of place.
    Pergunte ao FixBot
    Comentar
  9. Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 9, imagem 1 %32 Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 9, imagem 2 %32
    • Carefully pull on the battery cover until the rubber tab slides out of the aluminum casing.
    Pergunte ao FixBot
    Comentar
  10. Bose SoundLink Mini Button Switch Circuit Board Replacement, Button Switch Circuit Board: passo 10, imagem 1 %32
    • Remove the sponge (save for later replacement) and gently flip the black tab 90 degrees to release the connectors grip on the ribbon cable. Remove the ribbon cable from the connector.
    • The black tab must be flipped up in order to reinsert the ribbon cable on reassembly.
    Pergunte ao FixBot
    Comentar
  11. Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 11, imagem 1 %32 Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 11, imagem 2 %32 Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 11, imagem 3 %32
    • Use a Metal Spudger to pry up the plastic divider.
    Pergunte ao FixBot
    Comentar
  12. Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 12, imagem 1 %32 Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 12, imagem 2 %32
    • When removing the plastic divider be careful not to damage the wire strip sliding through it.
    Pergunte ao FixBot
    Comentar
  13. Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 13, imagem 1 %32 Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 13, imagem 2 %32
    • Reach through the battery compartment hole and unplug the power strip shown.
    Pergunte ao FixBot
    Comentar
  14. Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 14, imagem 1 %32 Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 14, imagem 2 %32 Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 14, imagem 3 %32
    • Remove both circuit boards by wiggling them up and out of the casing.
    • Unplug the speaker wires connected and fully remove both circuit boards.
    • When unplugging the speaker wires, squeeze the white connector piece to release the wires.
    Pergunte ao FixBot
    Comentar
  15. Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 15, imagem 1 %32 Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 15, imagem 2 %32
    • Unhook the speaker wires clipped onto the button switch circuit board.
    Pergunte ao FixBot
    Comentar
  16. Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 16, imagem 1 %32 Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 16, imagem 2 %32 Bose SoundLink Mini Button Switch Circuit Board Replacement: passo 16, imagem 3 %32
    • Use a nylon or metal spudger to slightly lift up on the button switch circuit board.
    • Pull the button switch circuit board straight out from the casing.
    Pergunte ao FixBot
    Comentar
Conclusão
16 outras pessoas executaram este guia.
Jordan Smith
Membro desde: 10/01/15
937 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 1-23, Maness Fall 2015 Membro de Cal Poly, Team 1-23, Maness Fall 2015
CPSU-MANESS-F15S1G23
4 Membros
Autoria de 24 guias
12Comentários do guia
Hello
Where I can buy circuit
candellaaria - Responder Compartilhar
Yes were can we get the replacement part? ?
sonny goddin - Responder Compartilhar
Hi sonny,
did you find this part ? (the first circuit board)
luc.lacouture - Responder Compartilhar
Hi
Can you get the relacement part for the mini II or is it the same - and if
- where and how to order for delivery to Europe?
Andreas Burckhart - Responder Compartilhar
Kindly can you tell me is th bose Soundlink mini first generation has an update or not, because it started no charge and the ember ligy keep flashing and some times reed color , I bought a new battery but still the same now it’s playing up
Moqdam Aljwrany - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 58
Últimos 30 dias: 298
Ao todo: 40,737
