Ir para o conteúdo principal
Bose On-Ear headphones Ear Cushion Replacement
O que você precisa
  1. Bose On-Ear headphones Ear Cushion Replacement, Ear Cushion: passo 1, imagem 1 %32 Bose On-Ear headphones Ear Cushion Replacement, Ear Cushion: passo 1, imagem 2 %32 Bose On-Ear headphones Ear Cushion Replacement, Ear Cushion: passo 1, imagem 3 %32
    • Here is the Bose Tricore OE headset. Slightly worn and a torn left ear cushion
    • To remove an existing ear cushion one would simply be applying a bit of force between the ear pads and the housing. The ear cushion will simply snap off
    • This shows the snaps that attach the ear pad to the case.
  2. Bose On-Ear headphones Ear Cushion Replacement: passo 2, imagem 1 %32 Bose On-Ear headphones Ear Cushion Replacement: passo 2, imagem 2 %32 Bose On-Ear headphones Ear Cushion Replacement: passo 2, imagem 3 %32
    • Since the ear cushion was already torn off on this one, simply clean the mating surfaces from all debris left by the old ear cushion
    • All left over foam and adhesive tape needs to be removed. This will ensure a proper fit.
    • Here is a look at the back of the replacement cushion.
  3. Bose On-Ear headphones Ear Cushion Replacement: passo 3, imagem 1 %32 Bose On-Ear headphones Ear Cushion Replacement: passo 3, imagem 2 %32 Bose On-Ear headphones Ear Cushion Replacement: passo 3, imagem 3 %32
    • Position the cushion so that the orientation aligns the two holes with the two pins on the headphones.
    • Place the new ear cushion on the headphones ensuring the holes and pins are lined up.
    • A simple squeeze on the ear cushion will snap the plastic to the headphones.
  4. Bose On-Ear headphones Ear Cushion Replacement: passo 4, imagem 1 %32
    • Good as new and ready to jam!
Conclusão
Uma outra pessoa concluiu este guia.
oldturkey03
Membro desde: 09/29/10
782.402 Reputação
Autoria de 119 guias
Equipe
Global Fixers Membro de Global Fixers
Community
Membros da 33
Autoria de 543 guias
Um comentário
Thanks for showing the steps
Rajiv Garg - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 58
Duração total: 7,296
