Ir para o conteúdo principal
Bosch PS21 Motor Replacement
O que você precisa
    1. Bosch PS21 Motor Replacement, Battery: passo 1, imagem 1 %32
      • Pinch the two release tabs on the sides of the battery, and slide the battery out.
      Pergunte ao FixBot
      Comentar
    1. Bosch PS21 Motor Replacement, Motor: passo 2, imagem 1 %32 Bosch PS21 Motor Replacement, Motor: passo 2, imagem 2 %32
      Ferramenta utilizada neste passo:
      $3.99
      • After removing the battery pack, locate the clip that connects the two halves of the outer casing shown in the picture. Remove the clip using angled tweezers or a similar tool. Save the clip for reassembly.
      Pergunte ao FixBot
      Comentar
    2. Bosch PS21 Motor Replacement: passo 3, imagem 1 %32
      • Locate the eight 5.5 mm screws as shown in the picture.
      • Remove each screw using a small Phillips head screw driver. Save all the screws for reassembly.
      Pergunte ao FixBot
      Comentar
    3. Bosch PS21 Motor Replacement: passo 4, imagem 1 %32 Bosch PS21 Motor Replacement: passo 4, imagem 2 %32
      • Starting at the rear of the drill, use a wedge to separate the two halves of the outer case at the parting line.
      Pergunte ao FixBot
      Comentar
    4. Bosch PS21 Motor Replacement: passo 5, imagem 1 %32 Bosch PS21 Motor Replacement: passo 5, imagem 2 %32
      • The motor and trigger assembly are connected by two wires. Do not pull or put tension on these wires.
      • Lift up the metal tab as shown in the first picture to free the trigger assembly.
      • Gently dislodge the motor and trigger assembly from the drill case. Remove the components as one piece, shown in the second picture.
      Pergunte ao FixBot
      Comentar
    5. Bosch PS21 Motor Replacement: passo 6, imagem 1 %32 Bosch PS21 Motor Replacement: passo 6, imagem 2 %32 Bosch PS21 Motor Replacement: passo 6, imagem 3 %32
      • Be sure to not grip the pliers too firmly, as it could cause damage to the wire connectors.
      • Firmly secure the motor assembly in place. Using a set of pliers, carefully pull the black wire connector away from the motor. Repeat this action with the red wire connector.
      • The wire connections on the motor are color coded, matching the color wire that connects there.
      Pergunte ao FixBot
      Comentar
    6. Bosch PS21 Motor Replacement: passo 7, imagem 1 %32 Bosch PS21 Motor Replacement: passo 7, imagem 2 %32 Bosch PS21 Motor Replacement: passo 7, imagem 3 %32
      • Once the wires have been disconnected, separate the trigger mechanism from the motor assembly.
      • Place your hands on each end of mechanism and carefully pull apart the assembly in order to separate the gearbox from the motor.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
IUPUI, Team 1-2, Harley Spring 2016 Membro de IUPUI, Team 1-2, Harley Spring 2016
IUPUI-HARLEY-S16S1G2
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 42
Ao todo: 3,837
