Ir para o conteúdo principal
Boot Zipper Replacement
O que você precisa
  1. Boot Zipper Replacement, Zipper: passo 1, imagem 1 %32 Boot Zipper Replacement, Zipper: passo 1, imagem 2 %32
    • Using a seam ripper, carefully remove the stitching at the top of the boot on either side of the zipper.
    • Only remove enough to free the zipper, about ¾ of an inch.
    Pergunte ao FixBot
    Comentar
  2. Boot Zipper Replacement: passo 2, imagem 1 %32 Boot Zipper Replacement: passo 2, imagem 2 %32 Boot Zipper Replacement: passo 2, imagem 3 %32
    • Remove the stitching on the heel side of the zipper.
    • The stitches on the heel side connect four layers of material: the lining, the zipper underlay, the zipper, and the outer leather.
    • Work between the leather and the zipper by pulling apart the leather and zipper and inserting the seam ripper into the gap.
    Pergunte ao FixBot
    Comentar
  3. Boot Zipper Replacement: passo 3, imagem 1 %32 Boot Zipper Replacement: passo 3, imagem 2 %32
    • Remove the stitching on the toe side of the zipper.
    • The stitches on the toe side connect three layers of material: the lining, the zipper, and the outer leather.
    • Set aside the original zipper.
    Pergunte ao FixBot
    Comentar
  4. Boot Zipper Replacement: passo 4, imagem 1 %32
    • Remove any leftover thread.
    Pergunte ao FixBot
    Comentar
  5. Boot Zipper Replacement: passo 5, imagem 1 %32 Boot Zipper Replacement: passo 5, imagem 2 %32
    • Measure your zipper against the boot.
    • Use a pin to mark how long it should be.
    Pergunte ao FixBot
    Comentar
  6. Boot Zipper Replacement: passo 6, imagem 1 %32
    • If your zipper is too long, trim it about an inch below your pin.
    Pergunte ao FixBot
    Comentar
  7. Boot Zipper Replacement: passo 7, imagem 1 %32 Boot Zipper Replacement: passo 7, imagem 2 %32
    • Fold down the excess fabric at the top of the zipper twice to create a right angle.
    Pergunte ao FixBot
    Comentar
  8. Boot Zipper Replacement: passo 8, imagem 1 %32 Boot Zipper Replacement: passo 8, imagem 2 %32 Boot Zipper Replacement: passo 8, imagem 3 %32
    • Stitch in place.
    • Use pliers if the fabric is too thick to push the needle through easily.
    Pergunte ao FixBot
    Comentar
  9. Boot Zipper Replacement: passo 9, imagem 1 %32 Boot Zipper Replacement: passo 9, imagem 2 %32
    • Pin your new zipper to the outer leather on the heel side.
    • Be careful to put your pins through the existing holes in the leather to avoid damaging the leather further.
    Pergunte ao FixBot
    Comentar
  10. Boot Zipper Replacement: passo 10, imagem 1 %32
    • Using a backstitch, sew the zipper to the leather along the inner row of stitching.
    • Be careful to put your needle through the existing holes in the leather to avoid damaging the leather further.
    Pergunte ao FixBot
    Comentar
  11. Boot Zipper Replacement: passo 11, imagem 1 %32 Boot Zipper Replacement: passo 11, imagem 2 %32
    • Repeat steps 8 and 9 for the toe side of the zipper.
    Pergunte ao FixBot
    Comentar
  12. Boot Zipper Replacement: passo 12, imagem 1 %32 Boot Zipper Replacement: passo 12, imagem 2 %32
    • Pin the lining to the zipper and leather on the toe side.
    Pergunte ao FixBot
    Comentar
  13. Boot Zipper Replacement: passo 13, imagem 1 %32 Boot Zipper Replacement: passo 13, imagem 2 %32
    • Using a backstitch, sew the lining into place along the outer row of stitching.
    Pergunte ao FixBot
    Comentar
  14. Boot Zipper Replacement: passo 14, imagem 1 %32 Boot Zipper Replacement: passo 14, imagem 2 %32
    • Pin the lining and zipper underlay to the zipper and outer leather on the heel side.
    Pergunte ao FixBot
    Comentar
  15. Boot Zipper Replacement: passo 15, imagem 1 %32
    • Using a backstitch, sew the lining and zipper underlay into place along the outer row of stitching.
    Pergunte ao FixBot
    Comentar
  16. Boot Zipper Replacement: passo 16, imagem 1 %32 Boot Zipper Replacement: passo 16, imagem 2 %32
    • This should be the final outcome after you repair the boot.
    Pergunte ao FixBot
    Comentar
Linha de Chegada
Alex
Membro desde: 11/05/24
258 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 4-2, Vidal-Chiesa Fall 2024 Membro de UC Davis, Team 4-2, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S4G2
3 Membros
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 32
Últimos 30 dias: 133
Ao todo: 2,940
