Ir para o conteúdo principal
Body Panel Removal
O que você precisa
  1. Body Panel Removal, Remove film door: passo 1, imagem 1 %32
    • Push down the latch to release the film door.
    Pergunte ao FixBot
    Comentar
  2. Body Panel Removal, Remove top cover screws: passo 2, imagem 1 %32 Body Panel Removal, Remove top cover screws: passo 2, imagem 2 %32 Body Panel Removal, Remove top cover screws: passo 2, imagem 3 %32
    • Remove two 7.5 mm #00 screws.
    • Remove one 9.0 mm #00 screw.
    • Remove one 13.5 mm #00 screw from inside the battery compartment.
    Pergunte ao FixBot
    Comentar
  3. Body Panel Removal, Remove top cover screws: passo 3, imagem 1 %32 Body Panel Removal, Remove top cover screws: passo 3, imagem 2 %32 Body Panel Removal, Remove top cover screws: passo 3, imagem 3 %32
    • Push the button to pop up the flash.
    • Remove one 3.5 mm #00 screw.
    • Remove one 5.5 mm #00 screw.
    Pergunte ao FixBot
    Comentar
  4. Body Panel Removal, Lift top cover: passo 4, imagem 1 %32
    • Carefully lift the top cover away from the body to access wired connections.
    • The top cover is still connected in several locations.
    Pergunte ao FixBot
    Comentar
  5. Body Panel Removal, Access flash connections: passo 5, imagem 1 %32 Body Panel Removal, Access flash connections: passo 5, imagem 2 %32
    • Peel back the corner of the rubber grip.
    • Remove the small plastic cover.
    • Be careful not to short the wires before the flash capacitors have been properly discharged.
    Pergunte ao FixBot
    Comentar
  6. Body Panel Removal, Discharge flash capacitors: passo 6, imagem 1 %32
    • Use a 1kΩ-10kΩ high power resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
    • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
    Pergunte ao FixBot
    Comentar
  7. Body Panel Removal, Disconnect right flex cable: passo 7, imagem 1 %32
    • Carefully lift the sides of the white latch.
    • Hold the flex PCB on the camera body in place as you lift to prevent damaging the flex.
    Pergunte ao FixBot
    Comentar
  8. Body Panel Removal, Disconnect left flex cable: passo 8, imagem 1 %32
    • Desolder the red wire.
    Pergunte ao FixBot
    Comentar
  9. Body Panel Removal, Desolder flash connections: passo 9, imagem 1 %32 Body Panel Removal, Desolder flash connections: passo 9, imagem 2 %32
    • Desolder blue, black, brown and green wires.
    • Remove the loose shim washer if present.
    Pergunte ao FixBot
    Comentar
  10. Body Panel Removal, Desolder the flash flex cable: passo 10, imagem 1 %32 Body Panel Removal, Desolder the flash flex cable: passo 10, imagem 2 %32
    • Remove the piece of cellophane tape covering the flex connections.
    • Desolder flex connetions.
    Pergunte ao FixBot
    Comentar
  11. Body Panel Removal, Remove bottom cover: passo 11, imagem 1 %32 Body Panel Removal, Remove bottom cover: passo 11, imagem 2 %32 Body Panel Removal, Remove bottom cover: passo 11, imagem 3 %32
    • Use isopropyl alcohol to soften the adhesive under the country plate and remove.
    • Remove one 5mm #00 screw.
    • Remove one 7.5mm #00 screw.
    • Remove two 4.5mm #00 screws.
    • Remove one 5.5mm #00 screw.
    • Remove the plastic frame around the accessory grip contacts.
    • Reassembly Note: The camera can be checked for functionality at this point. Install the rear door, insert a fresh pair of batteries and try to fire the shutter.
    Pergunte ao FixBot
    Comentar
  12. Body Panel Removal, Remove front left cover: passo 12, imagem 1 %32
    • Remove one 4.0 mm #00 screw.
    • Remove left cover.
    Pergunte ao FixBot
    Comentar
  13. Body Panel Removal, Remove front cover: passo 13, imagem 1 %32
    • Remove front cover.
    Pergunte ao FixBot
    Comentar
  14. Body Panel Removal, Unscrew front right cover: passo 14, imagem 1 %32 Body Panel Removal, Unscrew front right cover: passo 14, imagem 2 %32 Body Panel Removal, Unscrew front right cover: passo 14, imagem 3 %32
    • Remove one 6.0 mm #00 screw.
    • Remove two 3.5 mm #00 screws.
    • Remove one 5.0 mm #00 screw.
    • Remove the strap lug.
    Pergunte ao FixBot
    Comentar
  15. Body Panel Removal, Remove the front right cover: passo 15, imagem 1 %32
    • Carefully pull the right panel away from the body. It is still attached.
    • Desolder the flex connections.
    Pergunte ao FixBot
    Comentar
Conclusão
Sam Gustafson
Membro desde: 09/01/22
11.996 Reputação
Autoria de 78 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 44
Ao todo: 592
