Ir para o conteúdo principal
Blu Grand M2 Charging Port Assembly Replacement
O que você precisa
  1. Blu Grand M2 Charging Port Assembly Replacement, Charging Port Assembly: passo 1, imagem 1 %32
    • Remove the screws with the T2 Torx screwdriver.
    • Place screws off to the side.
  2. Blu Grand M2 Charging Port Assembly Replacement: passo 2, imagem 1 %32 Blu Grand M2 Charging Port Assembly Replacement: passo 2, imagem 2 %32
    • Once the Torx screws have been removed, use a pry tool and a suction tool to remove the back plate.
    • Using the T2 Torx screwdriver, remove the six Torx screws on the motherboard.
    • Make sure to disconnect all other connections from the camera.
  3. Blu Grand M2 Charging Port Assembly Replacement: passo 3, imagem 1 %32
    • Carefully pry the motherboard assembly from the phone.
    • The charging port assembly is soldered to the motherboard piece. Remove the port with a soldering iron.
    • Once you have removed the faulty port, replace it with the new port. Attach the new charging port with the soldering iron.
    • After installing the new port, repeat the steps in reverse order to reassemble the phone.
    • How to Solder and Desolder Connections
Conclusão
Uma outra pessoa concluiu este guia.
Richard Hills
Membro desde: 09/10/18
150 Reputação
Autoria de 1 guia
Equipe
Gateway, Team S1-G3, Luster Fall 2018 Membro de Gateway, Team S1-G3, Luster Fall 2018
GCC-LUSTER-F18S1G3
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 534
