Ir para o conteúdo principal
Blu Grand M2 Power Button Replacement
O que você precisa
  1. Blu Grand M2  Power Button Replacement, Power Button: passo 1, imagem 1 %32
    • Using a T2 Torx Screwdriver, remove the two screws from the bottom edge of the phone.
    Pergunte ao FixBot
    Comentar
  2. Blu Grand M2  Power Button Replacement: passo 2, imagem 1 %32 Blu Grand M2  Power Button Replacement: passo 2, imagem 2 %32
    • Apply the suction tool to the back panel near the bottom edge.
    • Carefully slide the device pick between the back panel and bottom edge.
    • Insert the opening tool into the gap created by the device pick.
    • While holding the suction tool, use the opening tool to gently pry the back panel off.
    • Be Cautious to not damage the phone display and or the inside components while using the pry tool and suction tool.
    Pergunte ao FixBot
    Comentar
  3. Blu Grand M2  Power Button Replacement: passo 3, imagem 1 %32
    • Take the end of the opening tool and push the old power button out of its socket.
    • Remove the old power button.
    Pergunte ao FixBot
    Comentar
  4. Blu Grand M2  Power Button Replacement: passo 4, imagem 1 %32
    • Place the new BLU Grand M2 power button in the socket.
    Pergunte ao FixBot
    Comentar
Conclusão
Alan Rodriguez
Membro desde: 09/10/18
311 Reputação
Autoria de 2 guias
Equipe
Gateway, Team S1-G3, Luster Fall 2018 Membro de Gateway, Team S1-G3, Luster Fall 2018
GCC-LUSTER-F18S1G3
4 Membros
Autoria de 8 guias
1Comentário do guia
Don’t forget to remove the SIM card
Jonathan - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 18
Ao todo: 714
