Ir para o conteúdo principal
BlackBerry R900M Display Replacement
O que você precisa
  1. BlackBerry R900M Display Replacement, Case Disassembly: passo 1, imagem 1 %32
    • Use a T9 Screwdriver to unscrew the two screws on the backside of the BlackBerry, one on the bottom left and one on the top right.
    Pergunte ao FixBot
    Comentar
  2. BlackBerry R900M Display Replacement: passo 2, imagem 1 %32
    • Remove the backside of the device and set aside for later use.
    Pergunte ao FixBot
    Comentar
  3. BlackBerry R900M Display Replacement: passo 3, imagem 1 %32 BlackBerry R900M Display Replacement: passo 3, imagem 2 %32
    • Remove the rubber placement pad that sits under the battery and set aside for later use. Gently fold back the battery, making sure the small plug connecting the battery to the logic board remains intact. Extra care should be taken as this part is quite delicate and easy to damage.
    Pergunte ao FixBot
    Comentar
  4. BlackBerry R900M Display Replacement: passo 4, imagem 1 %32
    • Use the T9 Screwdriver to remove the five visible screws: Top right, bottom right, middle center, bottom center, bottom left.
    Pergunte ao FixBot
    Comentar
  5. BlackBerry R900M Display Replacement: passo 5, imagem 1 %32 BlackBerry R900M Display Replacement: passo 5, imagem 2 %32
    • Carefully remove the board from the device by gently pushing on the screen from the front side. The battery, screen, and scroll wheel are all connected to the logic board. Be sure to support these components so they do not break.
    • Note the placement of two additional rubber pieces that cling loosely to the logic board. It is okay to let these pieces fall loose.
    • One is located below the scrollwheel.
    • Another is located behind the screen.
    Pergunte ao FixBot
    Comentar
  6. BlackBerry R900M Display Replacement, Display: passo 6, imagem 1 %32 BlackBerry R900M Display Replacement, Display: passo 6, imagem 2 %32
    • Pull out the two black clips securing the screen’s ribbon so that they are as far out as they will go.
    • Gently remove the screen’s ribbon from the slot. Be sure to support the screen and any connected parts.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Cal Poly, Team 33-83, Johann Spring 2010 Membro de Cal Poly, Team 33-83, Johann Spring 2010
CPSU-JOHANN-S10S33G83
4 Membros
Autoria de 9 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 45
Ao todo: 1,686
