Ir para o conteúdo principal
BlackBerry Key2 Disassembly
  1. BlackBerry Key2 Disassembly, Blackberry Key2: passo 1, imagem 1 %32 BlackBerry Key2 Disassembly, Blackberry Key2: passo 1, imagem 2 %32 BlackBerry Key2 Disassembly, Blackberry Key2: passo 1, imagem 3 %32
    • The start of our disassembly. Turn off your device before start.
    • Remove the sim card bracket.
  2. BlackBerry Key2 Disassembly, Heating process: passo 2, imagem 1 %32 BlackBerry Key2 Disassembly, Heating process: passo 2, imagem 2 %32 BlackBerry Key2 Disassembly, Heating process: passo 2, imagem 3 %32
    • Apply heat to the back of the phone to remove the plastic cover.
    • With a pry tool of your preference start to lift up the back cover. Be careful on that part of the process.
  3. BlackBerry Key2 Disassembly, Removing the screws: passo 3, imagem 1 %32 BlackBerry Key2 Disassembly, Removing the screws: passo 3, imagem 2 %32 BlackBerry Key2 Disassembly, Removing the screws: passo 3, imagem 3 %32
    • Remove all the screws.
    • Remove the loudspeaker module.
  4. BlackBerry Key2 Disassembly, Antenna cable: passo 4, imagem 1 %32 BlackBerry Key2 Disassembly, Antenna cable: passo 4, imagem 2 %32 BlackBerry Key2 Disassembly, Antenna cable: passo 4, imagem 3 %32
    • Use the point of a plastic spudger to lift the antenna cable connector up off of its socket on the logic board.
  5. BlackBerry Key2 Disassembly, Back bracket: passo 5, imagem 1 %32 BlackBerry Key2 Disassembly, Back bracket: passo 5, imagem 2 %32 BlackBerry Key2 Disassembly, Back bracket: passo 5, imagem 3 %32
    • Be gentle lifting up the back bracket.
    • I marked in red all the flex cables connected on the motherboard. You got to remove them all.
    • Start disconnecting the battery flex cable.
  6. BlackBerry Key2 Disassembly, Removing the flex cables: passo 6, imagem 1 %32 BlackBerry Key2 Disassembly, Removing the flex cables: passo 6, imagem 2 %32 BlackBerry Key2 Disassembly, Removing the flex cables: passo 6, imagem 3 %32
    • Disconnect and remove the rear camera.
    • Then continue disconnecting the other flex cables.
    • Don't forget to use a plastic tool.
  7. BlackBerry Key2 Disassembly, Removing the motherboard.: passo 7, imagem 1 %32 BlackBerry Key2 Disassembly, Removing the motherboard.: passo 7, imagem 2 %32 BlackBerry Key2 Disassembly, Removing the motherboard.: passo 7, imagem 3 %32
    • Disconnect all the flex cables.
    • Start from the bottom .
    • Lift up gentle and check the last photo,there's a little detail on the proximity sensor. You'll have to disconnect it after lift up the motherboard.
    • Observation : this way worked better for me without damaging the proximity sensor. It doesn't change anything try to heat up a little bit and removing it before remove the motherboard.
  8. BlackBerry Key2 Disassembly, Removing the LCD.: passo 8, imagem 1 %32 BlackBerry Key2 Disassembly, Removing the LCD.: passo 8, imagem 2 %32 BlackBerry Key2 Disassembly, Removing the LCD.: passo 8, imagem 3 %32
    • Heat the LCD before lift.
  9. BlackBerry Key2 Disassembly, Final: passo 9, imagem 1 %32
    • And we're done.
Conclusão
15 outras pessoas executaram este guia.
DouglasVinicio
Membro desde: 09/27/18
1.687 Reputação
Autoria de 1 guia
4Comentários do guia
The antenna connector on the daughter board can be broken off really easily. Pop off the connectors carefully. A hot air workstation will make quick work of re attaching tho.
Grant Marshall - Responder Compartilhar
OMG that’s probably exactly what happened to me. now the phone does not receive network anymore any suggestions on what to do ?? i am quite certain i cannot get another antenna or board. do you think i can find a matching antenna from another phone entirely ???
Chinedu - Compartilhar
Thanks for this tear down! At what step can the battery be removed? It *appears* to be mid-step-5
charleslindsay - Responder Compartilhar
Same her no Network so my Key2 ist useless :/
Christoph Alber - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 31
Últimos 30 dias: 149
Ao todo: 17,984
