Ir para o conteúdo principal
BlackBerry 7130e battery replacement
O que você precisa
  1. BlackBerry 7130e battery replacement, battery: passo 1, imagem 1 %32
    • Turn the phone over so that the screen is facing the work surface
    Pergunte ao FixBot
    Comentar
  2. BlackBerry 7130e battery replacement: passo 2, imagem 1 %32
    • Press your thumb against the battery latch. While pressing on latch, slide off battery cover towards the bottom of the phone.
    • You may need to apply considerable force on the latch at the bottom of the phone to complete this successfully.
    Pergunte ao FixBot
    Comentar
  3. BlackBerry 7130e battery replacement: passo 3, imagem 1 %32
    • Remove the battery by pushing downward on the area where prongs connect to bottom inside of the phone while using a thumb, finger, or tool to pull on the top of the battery to lift it out.
    Pergunte ao FixBot
    Comentar
Conclusão
Sean Tiernan
Membro desde: 01/20/10
5 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 3-16, Maness Winter 2010 Membro de Cal Poly, Team 3-16, Maness Winter 2010
CPSU-MANESS-W10S3G16
4 Membros
Autoria de 11 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 28
Ao todo: 3,300
