Ir para o conteúdo principal
Black and Decker Pivot MAX Power Switch Replacement
O que você precisa
  1. Black and Decker Pivot MAX Power Switch Replacement, Battery: passo 1, imagem 1 %32 Black and Decker Pivot MAX Power Switch Replacement, Battery: passo 1, imagem 2 %32
    • Press in and hold the release button.
    • Rotate the dust filter chamber counter-clockwise.
    • Remove the dust filter chamber.
  2. Black and Decker Pivot MAX Power Switch Replacement: passo 2, imagem 1 %32
    • Remove the two 10 mm screws from the motor casing with a Phillips #1 screwdriver.
  3. Black and Decker Pivot MAX Power Switch Replacement: passo 3, imagem 1 %32
    • Pull the battery cover up and then slide it away from the motor to remove.
  4. Black and Decker Pivot MAX Power Switch Replacement: passo 4, imagem 1 %32
    • Remove the battery unit by pulling it out of the main body.
  5. Black and Decker Pivot MAX Power Switch Replacement: passo 5, imagem 1 %32
    • Disconnect the quick connect wire harness that connects the motor and battery located in the battery storage compartment.
  6. Black and Decker Pivot MAX Power Switch Replacement, Pivot Lock Button: passo 6, imagem 1 %32
    • Remove the handle cover by removing the three PH1 20mm screws
  7. Black and Decker Pivot MAX Power Switch Replacement: passo 7, imagem 1 %32
    • Pull out the pivot lock button.
  8. Black and Decker Pivot MAX Power Switch Replacement, Power Switch: passo 8, imagem 1 %32 Black and Decker Pivot MAX Power Switch Replacement, Power Switch: passo 8, imagem 2 %32 Black and Decker Pivot MAX Power Switch Replacement, Power Switch: passo 8, imagem 3 %32
    • Lift the battery tray after removing the screws
    • Remove the handle parts from the handle area.
  9. Black and Decker Pivot MAX Power Switch Replacement: passo 9, imagem 1 %32 Black and Decker Pivot MAX Power Switch Replacement: passo 9, imagem 2 %32
    • Pull the power switch out softly.
    • Desolder the wires from the old power switch to the new one.
    • Check out our Como soldar e dessoldar contatos guide if you need any help!
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Ao todo: 1,046
