Introdução
This guide describes how to replace the Black and Decker PS1800 switch. A soldering gun is necessary to replace the switch. Personal protective equipment is suggested.
O que você precisa
Lay the drill on its side, assuring that the screw holes are facing upwards.
Remove seven 12 mm screws using a Phillips #00 screwdriver.
Identify the switch in center of the drill.
Remove the screws from the switch.
Remove the switch cover.
Uma outra pessoa concluiu este guia.
