Introdução
The battery contact board is an internal component and will require disassembly of the screwdriver casing. Due to disassembly of the casing, you will be required to use a few special tools listed in the outer casing replacement guide. Consult the outer casing replacement guide for instructions on removing the casing. Also, use caution when working on the screwdriver internally - always unplug the battery before replacing any components. This guide will also require a soldering iron and basic soldering skills for replacing the battery contact board.
O que você precisa
Remove the stickers found on the bottom and sides of the LI4000, using a spudger.
After consulting the replacement guide for steps on removing the outer casing, locate the negative terminal of the battery.
Remove the negative (black) wire by pulling back gently.
Uma outra pessoa concluiu este guia.
