Ir para o conteúdo principal
Black and Decker LDX 120C Light Replacement
O que você precisa
  1. Black and Decker LDX 120C Light  Replacement, Outer Case: passo 1, imagem 1 %32
    • For this guide we will need to use a 1.0 mm phillips #1 screw.
    • There are a total of thirteen screws that need to be removed in order to open the drill and access the interior components.
  2. Black and Decker LDX 120C Light  Replacement: passo 2, imagem 1 %32
    • Remove the four screws on the back top side of the drill.
  3. Black and Decker LDX 120C Light  Replacement: passo 3, imagem 1 %32
    • Remove the four screws that connect the chuck to the drill.
  4. Black and Decker LDX 120C Light  Replacement: passo 4, imagem 1 %32
    • Remove the five screws on the front side of the drill.
  5. Black and Decker LDX 120C Light  Replacement: passo 5, imagem 1 %32
    • Gently grab both sides of the drill casing, and separate both sides from each other.
  6. Black and Decker LDX 120C Light  Replacement: passo 6, imagem 1 %32
    • At this point you should be able to separate both as illustrated.
  7. Black and Decker LDX 120C Light  Replacement: passo 7, imagem 1 %32
    • Now all the components of the drill are visible and can be accessed.
  8. Black and Decker LDX 120C Light  Replacement, Light: passo 8, imagem 1 %32
    • After following the prerequisite guide the drill is now open and you can see all the components of the drill.
  9. Black and Decker LDX 120C Light  Replacement: passo 9, imagem 1 %32
    • First separate the top part of the drill, which includes the motor and the chuck, from the rest of the components.
    • Remove carefully so that wire connection is not damaged throughout this process.
  10. Black and Decker LDX 120C Light  Replacement: passo 10, imagem 1 %32
    • Then separate the other component which includes the trigger, light, and the connection to the battery.
    • Do this carefully so that no wire connection or any component gets damaged.
  11. Black and Decker LDX 120C Light  Replacement: passo 11, imagem 1 %32
    • First check if the connection to the light is not intact.
    • If the wiring is lose simply reconnect the wire.
    • Then check if the light bulb is not damaged in any way.
    • If the light bulb is broken or simply just burnt; simply replace the light bulb.
  12. Black and Decker LDX 120C Light  Replacement: passo 12, imagem 1 %32
    • Grab the connection of the light bulb.
  13. Black and Decker LDX 120C Light  Replacement: passo 13, imagem 1 %32
    • Using pliers cut the two connecting wires from the mother chip.
    • To prevent potential damage to the component, try desoldering the wires. Learn more about soldering here.
Conclusão
jeffrey zakka
Membro desde: 02/09/16
735 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 11-5, Cheng Spring 2016 Membro de USF Tampa, Team 11-5, Cheng Spring 2016
USFT-CHENG-S16S11G5
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 26
Últimos 30 dias: 67
Duração total: 17,427
