Ir para o conteúdo principal
Black and Decker 3-Cup Rice Cooker Spring Replacement
O que você precisa
    1. Black and Decker 3-Cup Rice Cooker Spring Replacement, Remove the Lid and Bowl: passo 1, imagem 1 %32
      • Make sure the device is unplugged before beginning disassembly!
      • Lift the lid and bowl from the top of the device.
      Pergunte ao FixBot
      Comentar
    2. Black and Decker 3-Cup Rice Cooker Spring Replacement, Turn the Device Upside-Down: passo 2, imagem 1 %32
      • Turn the device upside-down, so that the four legs of the device point upwards.
      Pergunte ao FixBot
      Comentar
    3. Black and Decker 3-Cup Rice Cooker Spring Replacement, Remove the Rubber Cushions: passo 3, imagem 1 %32 Black and Decker 3-Cup Rice Cooker Spring Replacement, Remove the Rubber Cushions: passo 3, imagem 2 %32
      • Each of the four legs has a rubber cushion on its bottom. For each cushion, insert a plastic opening tool between the plastic leg and rubber cushion, and pry off the rubber cushion.
      Pergunte ao FixBot
      Comentar
    4. Black and Decker 3-Cup Rice Cooker Spring Replacement, Remove the Spanning Screw: passo 4, imagem 1 %32
      • Using a spanner screwdriver, remove the one 10mm long 7mm diameter spanner screw from the side of the brass panel.
      Pergunte ao FixBot
      Comentar
    5. Black and Decker 3-Cup Rice Cooker Spring Replacement, Remove the Leg Screws: passo 5, imagem 1 %32
      • Using a Phillips screwdriver, remove the 10mm long 7mm diameter Phillips-head screws from the inside of all four legs.
      • The smaller leg at the bottom is now loose and not attached to the device. Set it aside.
      Pergunte ao FixBot
      Comentar
    6. Black and Decker 3-Cup Rice Cooker Spring Replacement, Remove the Brass Plate: passo 6, imagem 1 %32
      • Lift the brass plate off the device and set it aside.
      Pergunte ao FixBot
      Comentar
    7. Black and Decker 3-Cup Rice Cooker Spring Replacement, Color the Wires: passo 7, imagem 1 %32 Black and Decker 3-Cup Rice Cooker Spring Replacement, Color the Wires: passo 7, imagem 2 %32
      • Color coordinating wire groups make it easier to identify the wire groups during reassembly.
      • Inside the device, there are three junctions with wires joined by Phillips-head screws. The first is connected to two wires, and the other two are connected to three wires each.
      • Unscrew the screw at the junction near the opposite side of the device from the front panel.
      • Label each of the two wires at this junction with a single color of tape.
      Pergunte ao FixBot
      Comentar
    8. Black and Decker 3-Cup Rice Cooker Spring Replacement, Label the Second Wire Junction: passo 8, imagem 1 %32 Black and Decker 3-Cup Rice Cooker Spring Replacement, Label the Second Wire Junction: passo 8, imagem 2 %32
      • Unscrew the screw at the junction just clockwise from the button panel.
      • Label the three wires of this junction with tape of a second color.
      Pergunte ao FixBot
      Comentar
    9. Black and Decker 3-Cup Rice Cooker Spring Replacement, Label the Third Wire Junction: passo 9, imagem 1 %32 Black and Decker 3-Cup Rice Cooker Spring Replacement, Label the Third Wire Junction: passo 9, imagem 2 %32
      • Unscrew the screw from the wire junction just behind the front panel.
      • Label the three wires at this junction with a third color of tape.
      Pergunte ao FixBot
      Comentar
    1. Black and Decker 3-Cup Rice Cooker Spring Replacement, Unlock the brass latch: passo 10, imagem 1 %32 Black and Decker 3-Cup Rice Cooker Spring Replacement, Unlock the brass latch: passo 10, imagem 2 %32
      • Using a pair of pliers, bend the spring latch from a "[" shape to a "c" shape so that it fits through the silver-colored latch that holds it. Then pull the silver-colored beam up so that it detaches from the brass beam.
      Pergunte ao FixBot
      Comentar
    2. Black and Decker 3-Cup Rice Cooker Spring Replacement, Unscrew the surrounding screws: passo 11, imagem 1 %32 Black and Decker 3-Cup Rice Cooker Spring Replacement, Unscrew the surrounding screws: passo 11, imagem 2 %32
      • Unscrew the four 10 mm long 7mm diameter Phillips screws attached to the hotplate
      Pergunte ao FixBot
      Comentar
    3. Black and Decker 3-Cup Rice Cooker Spring Replacement, Remove the hotplate Piece: passo 12, imagem 1 %32 Black and Decker 3-Cup Rice Cooker Spring Replacement, Remove the hotplate Piece: passo 12, imagem 2 %32
      • Carefully turn the device over, either allowing the hotplate portion of the device to fall out, or catching it as it falls out.
      • For the next step, make sure the hotplate portion of the device has its flat side facing down.
      Pergunte ao FixBot
      Comentar
    4. Black and Decker 3-Cup Rice Cooker Spring Replacement, Unlock the Hotplate: passo 13, imagem 1 %32 Black and Decker 3-Cup Rice Cooker Spring Replacement, Unlock the Hotplate: passo 13, imagem 2 %32
      • Position a pair of pliers so that they are outside the hotplate's two inner silver-colored rectangular plates.
      • Carefully push the plates together to unlock the inner portion of the hotplate.
      Pergunte ao FixBot
      Comentar
    5. Black and Decker 3-Cup Rice Cooker Spring Replacement, Expose the Spring: passo 14, imagem 1 %32
      • Remove the non-spring portion of the hotplate by lifting it up, exposing the spring and brass locking latch underneath.
      Pergunte ao FixBot
      Comentar
    6. Black and Decker 3-Cup Rice Cooker Spring Replacement, Remove the Spring: passo 15, imagem 1 %32
      • Remove the 47 mm by 30 mm spring, by pulling it up and off the locking latch.
      • If the spring is in multiple pieces, does not compress and spring back easily, or otherwise does not behave like a spring, you will need to replace it.
      • To reassemble your device, follow these instructions in reverse order. The two silver latches will need to be bent outwards separately, and the brass latch will need to be bent back into a "["or "(" shape by holding the pliers to a 90 degree angle of that in the instructions.
      Pergunte ao FixBot
      Comentar
Linha de Chegada
6 outras pessoas executaram este guia.
Lillian Heng
Membro desde: 09/26/14
727 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 12-1, Forte Fall 2014 Membro de Cal Poly, Team 12-1, Forte Fall 2014
CPSU-FORTE-F14S12G1
5 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 45
Ao todo: 6,224
