Ir para o conteúdo principal
Bissell Zing 2156A Rear Filter Replacement
  1. Bissell Zing 2156A Rear Filter Replacement, Rear Filter: passo 1, imagem 1 %32
    • While holding the top of the vacuum with one hand, use the other hand to push the clamp down that holds the rear filter in place.
  2. Bissell Zing 2156A Rear Filter Replacement: passo 2, imagem 1 %32
    • Hold the grille with one hand.
    • With the other hand, grab ahold of the foam and separate it from the grille.
  3. Bissell Zing 2156A Rear Filter Replacement: passo 3, imagem 1 %32
    • Remove any large piece of debris by hand from the grille.
    • The grille can be gently rinsed over a faucet. Be sure to dry the grill before reassembly.
    • Remove any large piece of debris by hand gently from the foam.
    • The foam should never touch water or any kind of liquid.
    • If any part of the rear filter becomes damaged or too filthy to clean, replace it.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 55
