Ir para o conteúdo principal
Bissell CrossWave Cordless Max 2554A Handle Replacement
O que você precisa
  1. Bissell CrossWave Cordless Max 2554A Handle Replacement, Handle: passo 1, imagem 1 %32
    • Start by facing the vacuum away from you so that you are looking at the back side of the clean water tank.
  2. Bissell CrossWave Cordless Max 2554A Handle Replacement: passo 2, imagem 1 %32 Bissell CrossWave Cordless Max 2554A Handle Replacement: passo 2, imagem 2 %32 Bissell CrossWave Cordless Max 2554A Handle Replacement: passo 2, imagem 3 %32
    • The handle release mechanism is a small hole directly above the clean water tank and below the handle.
    • Using the pointed end of a spudger, press the mechanism to release the handle.
    • You might need to shimmy it a bit, as pressing too hard may prevent the handle from releasing.
  3. Bissell CrossWave Cordless Max 2554A Handle Replacement: passo 3, imagem 1 %32 Bissell CrossWave Cordless Max 2554A Handle Replacement: passo 3, imagem 2 %32
    • Remove the handle from the vacuum.
Conclusão
To reassemble your device, reinsert the handle back into the main body of the vacuum, listening for an audible click.
Uma outra pessoa concluiu este guia.
Craig Bowlin
Membro desde: 02/15/24
898 Reputação
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 28
Duração total: 196
