Ir para o conteúdo principal
Bissell CrossWave Cordless Max 2554A Charging Cord Replacement
O que você precisa
  1. Bissell CrossWave Cordless Max 2554A Charging Cord Replacement, Charging Cord: passo 1, imagem 1 %32 Bissell CrossWave Cordless Max 2554A Charging Cord Replacement, Charging Cord: passo 1, imagem 2 %32
    • Flip the charging base over, so that the support pillar is facing down.
  2. Bissell CrossWave Cordless Max 2554A Charging Cord Replacement: passo 2, imagem 1 %32 Bissell CrossWave Cordless Max 2554A Charging Cord Replacement: passo 2, imagem 2 %32
    • Remove the two 11.6 mm Phillips #1 screws deep within the pillar.
  3. Bissell CrossWave Cordless Max 2554A Charging Cord Replacement: passo 3, imagem 1 %32
    • Remove the plastic piece holding the cord, as well as the charging cord.
    • When replacing the charging cord, ensure that the new unit has the same voltage and current limits, as to not damage the internal battery.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 23
Duração total: 88
