Introdução
If the Bissell Crosswave Cordless Max (model 2554A) battery has died, this guide will show you how to replace the charging cord. This guide features information on common issues while charging. The charging port could be blocked or damaged. This guide has information to help with cleaning the port from dust or particle buildup. Replacing the cord is not as simple as buying a new one, but requires removal from the base. The cord attached to the docking station is easily replaceable once out from the base.
O que você precisa
Flip the charging base over, so that the support pillar is facing down.
