Ir para o conteúdo principal
Bissell CrossWave Cordless Max 2554A Battery Replacement
O que você precisa
  1. Bissell CrossWave Cordless Max 2554A Battery Replacement, Battery Assembly: passo 1, imagem 1 %32 Bissell CrossWave Cordless Max 2554A Battery Replacement, Battery Assembly: passo 1, imagem 2 %32
    • Remove the four 16 mm Phillips #2 screws at the back of the vacuum and below the clean water tank.
  2. Bissell CrossWave Cordless Max 2554A Battery Replacement: passo 2, imagem 1 %32 Bissell CrossWave Cordless Max 2554A Battery Replacement: passo 2, imagem 2 %32
    • Pull the battery assembly away from the main body.
    • There are still wires connecting the battery assembly to the main body. Do not use force to completely separate the two objects.
  3. Bissell CrossWave Cordless Max 2554A Battery Replacement: passo 3, imagem 1 %32 Bissell CrossWave Cordless Max 2554A Battery Replacement: passo 3, imagem 2 %32
    • Detach the wires holding the battery assembly to the main body by pressing down on the clip holding the connector together.
  4. Bissell CrossWave Cordless Max 2554A Battery Replacement, Battery: passo 4, imagem 1 %32 Bissell CrossWave Cordless Max 2554A Battery Replacement, Battery: passo 4, imagem 2 %32 Bissell CrossWave Cordless Max 2554A Battery Replacement, Battery: passo 4, imagem 3 %32
    • This step involves cutting live battery wires. If possible, use insulated cutting equipment and do not touch the exposed wires. Use wire cutters instead of the scissors shown in the images.
    • Cut the remaining yellow and black wires to detach the battery from the main body.
    • These wires do have a device connecting them to the wires on the main body, but these devices are unable to be removed without specialized equipment.
  5. Bissell CrossWave Cordless Max 2554A Battery Replacement: passo 5, imagem 1 %32 Bissell CrossWave Cordless Max 2554A Battery Replacement: passo 5, imagem 2 %32
    • The main body can now be set aside until reassembly.
  6. Bissell CrossWave Cordless Max 2554A Battery Replacement: passo 6, imagem 1 %32 Bissell CrossWave Cordless Max 2554A Battery Replacement: passo 6, imagem 2 %32
    • Remove the four silver 13.5 mm Phillips #2 screws.
    • Do not remove the two visible black screws. They hold the two halves of the battery case together and should not come apart.
  7. Bissell CrossWave Cordless Max 2554A Battery Replacement: passo 7, imagem 1 %32 Bissell CrossWave Cordless Max 2554A Battery Replacement: passo 7, imagem 2 %32
    • Slide the battery out of its housing.
    • Solder the wires from the new battery to the wires in the main body of the vacuum.
Conclusão
To reassemble your device, follow these instructions in reverse order. Make sure you properly insulate the wires that were cut when reconnecting them.
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 16
Últimos 30 dias: 68
Duração total: 231
