Introdução
This guide provides instructions for removing and replacing the gear in the Bendix Magneto: S6RN-23. The Magneto is an elecrical generator that uses magnets to create electrical current pulses. It is often used in ignition systems. A broken gear can stop the Bendix Magneto from rotating, causing incorrect timing of the system. This would cause an engine to either run erraticly or stop altogether.
O que você precisa
Use a #2 flat head screwdriver to remove the five screws from the body of the Magneto.
7 outras pessoas executaram este guia.
