Ir para o conteúdo principal
Benchmade Griptillian Disassembly
O que você precisa
    1. Benchmade Griptillian Disassembly, Close the blade and turn the knife to the side that has the belt clip: passo 1, imagem 1 %32
      • Be sure to make note of what side the belt clip is on for reassembly.
      Pergunte ao FixBot
      Comentar
    2. Benchmade Griptillian Disassembly, Remove screws: passo 2, imagem 1 %32
      • Use a T6 bit to remove the two screws holding the belt clip.
      Pergunte ao FixBot
      Comentar
    3. Benchmade Griptillian Disassembly, Remove T6 Screws: passo 3, imagem 1 %32
      • Use the T6 bit to remove the four screws holding the handle in place.
      Pergunte ao FixBot
      Comentar
    4. Benchmade Griptillian Disassembly, Turn the knife over: passo 4, imagem 1 %32
      • Turn the knife over and remove one T6 screw.
      Pergunte ao FixBot
      Comentar
    5. Benchmade Griptillian Disassembly, Remove the T8 screw: passo 5, imagem 1 %32
      • Turn the knife over and remove the T8 screw that is going through the hinge.
      Pergunte ao FixBot
      Comentar
    6. Benchmade Griptillian Disassembly, Remove the handle: passo 6, imagem 1 %32
      • Once you've removed the screw, you can remove the handle.
      Pergunte ao FixBot
      Comentar
    7. Benchmade Griptillian Disassembly, Drive pin out of the other handle: passo 7, imagem 1 %32
      • Using the T6 bit, drive the hinge pin out of the other handle.
      Pergunte ao FixBot
      Comentar
    8. Benchmade Griptillian Disassembly, Remove the other handle: passo 8, imagem 1 %32
      • Once you've done this you can remove the other handle.
      Pergunte ao FixBot
      Comentar
    9. Benchmade Griptillian Disassembly, Slide the blade out of the frame: passo 9, imagem 1 %32
      • Be sure to keep both brass washers. Sometimes they will stick to the frame or the blade.
      Pergunte ao FixBot
      Comentar
    10. Benchmade Griptillian Disassembly, Sand both sides of copper: passo 10, imagem 1 %32
      • Using 600 grit sandpaper and a flat surface, rub both sides of the copper washers until there is new material showing.
      Pergunte ao FixBot
      Comentar
    11. Benchmade Griptillian Disassembly, Reverse process to re assemble: passo 11, imagem 1 %32
      • Reverse process to re assemble.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Spin Modder
Membro desde: 07/21/22
256 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 70
Ao todo: 1,576
