Ir para o conteúdo principal
BenQ HT1075 Projector Blower Fan Replacement
O que você precisa
  1. BenQ HT1075 Projector Blower Fan Replacement, Lamp: passo 1, imagem 1 %32
    • Loosen the 2.5 mm Phillips #1 screw that holds the top assembly in place using a Philips #1 (PH1) screwdriver. This will enable you to lift and slide off the top cover.
    • Fully remove the top cover in order to get to the lamp housing.
    Pergunte ao FixBot
    Comentar
  2. BenQ HT1075 Projector Blower Fan Replacement: passo 2, imagem 1 %32
    • Carefully peel off the adhesive film covering the lamp housing.
    Pergunte ao FixBot
    Comentar
  3. BenQ HT1075 Projector Blower Fan Replacement: passo 3, imagem 1 %32
    • Using a Phillips #1 (PH1) screwdriver, loosen and remove the single 2.5 mm Phillips #1 screw that secures the lamp housing to the projector.
    Pergunte ao FixBot
    Comentar
  4. BenQ HT1075 Projector Blower Fan Replacement: passo 4, imagem 1 %32
    • Remove the lamp from the projector by pulling on the lamp handle.
    • Apply more force on the side opposite of the newly removed screw as you pull the lamp out.
    Pergunte ao FixBot
    Comentar
  5. BenQ HT1075 Projector Blower Fan Replacement, Circuit Board: passo 5, imagem 1 %32
    • Turn the projector over and remove the five 9.5 mm Phillips #1 screws that hold the back cover with a Phillips #1 (PH1) screwdriver.
    Pergunte ao FixBot
    Comentar
  6. BenQ HT1075 Projector Blower Fan Replacement, Remove the 6th screw holding the top cover: passo 6, imagem 1 %32
    • Flip the projector and remove the 6th and last crew.
    Pergunte ao FixBot
    Comentar
  7. BenQ HT1075 Projector Blower Fan Replacement: passo 7, imagem 1 %32
    • Using an opening tool, remove the top cover by first loosening its top cover.
    Pergunte ao FixBot
    Comentar
  8. BenQ HT1075 Projector Blower Fan Replacement: passo 8, imagem 1 %32 BenQ HT1075 Projector Blower Fan Replacement: passo 8, imagem 2 %32
    • Unplug the wire that connects the front cover to the circuit board.
    • Now use the opening tool to pry the front cover from the platform.
    • Gently pull the top cover from the rest of the frame.
    Pergunte ao FixBot
    Comentar
  9. BenQ HT1075 Projector Blower Fan Replacement: passo 9, imagem 1 %32 BenQ HT1075 Projector Blower Fan Replacement: passo 9, imagem 2 %32
    • To prevent potential for electrical damage, disconnect any wires connected to the circuit board.
    • Using the opening tool, loosen the sides of the platform. Then gently pull them off from the projector components.
    Pergunte ao FixBot
    Comentar
  10. BenQ HT1075 Projector Blower Fan Replacement: passo 10, imagem 1 %32 BenQ HT1075 Projector Blower Fan Replacement: passo 10, imagem 2 %32 BenQ HT1075 Projector Blower Fan Replacement: passo 10, imagem 3 %32
    • Remove these four 8.5 mm Phillips #1 screws using a Phillips #1 (PH1) screwdriver.
    • Afterwards, use a 5mm nut driver to remove the four remaining screws.
    • Use the opening tool to loosen the back cover then pull it off.
    Pergunte ao FixBot
    Comentar
  11. BenQ HT1075 Projector Blower Fan Replacement: passo 11, imagem 1 %32
    • With a Phillips #1 (PH1) screwdriver, remove the four 6.3 mm Phillips screws that hold the metal casing on top of the circuit board.
    • Remove the metal casing.
    Pergunte ao FixBot
    Comentar
  12. BenQ HT1075 Projector Blower Fan Replacement: passo 12, imagem 1 %32 BenQ HT1075 Projector Blower Fan Replacement: passo 12, imagem 2 %32
    • Using the Phillips #1 (PH1) screwdriver, remove the three 6.3 mm Phillips #1 screws holding down the circuit board.
    • Carefully pull the circuit board from the frame, adding force to the area where the pushbuttons are located.
    Pergunte ao FixBot
    Comentar
  13. BenQ HT1075 Projector Blower Fan Replacement, Blower Fan: passo 13, imagem 1 %32 BenQ HT1075 Projector Blower Fan Replacement, Blower Fan: passo 13, imagem 2 %32
    • Unscrew the Philips #1 (PH1) screw securing the green wire located at the bottom left of the metal casing.
    • Remove a second Philips #1 (PH1) screw that holds down the top of the metal casing located near the back of the projector’s lens.
    Pergunte ao FixBot
    Comentar
  14. BenQ HT1075 Projector Blower Fan Replacement: passo 14, imagem 1 %32
    • Remove three Philips #2 (PH2) screws that attach the metal casing to the platform.
    • Remove the metal casing by pulling it straight up.
    Pergunte ao FixBot
    Comentar
  15. BenQ HT1075 Projector Blower Fan Replacement: passo 15, imagem 1 %32
    • Remove the two Philips #2 (PH2) screws that hold down the black blower fan, located at top center of the circuit board.
    Pergunte ao FixBot
    Comentar
  16. BenQ HT1075 Projector Blower Fan Replacement: passo 16, imagem 1 %32
    • Remove the three Philips #1 (PH1) screws that attach the blower fan to the metal cover.
    • Gently remove the blower fan by pulling it directly upwards from the base.
    Pergunte ao FixBot
    Comentar
Conclusão
7 outras pessoas executaram este guia.
Gabriela Remulla
Membro desde: 09/26/17
1.026 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S6-G1, Banghart Fall 2017 Membro de Cal Poly, Team S6-G1, Banghart Fall 2017
CPSU-BANGHART-F17S6G1
5 Membros
Autoria de 9 guias
3Comentários do guia
I did the repair to clear out some dust and glass from a blown lamp. After putting it back together, I get lights most likely from no power at all. Do you think the next step would to be take back apart and make sure everything is connected correctly? I can be reached at jaspercloren@gmail.com or I will check back on here.
Thank you for all your write ups, they are very nice. I may suggest to get a closer view of the screws/bolts in case someone misplaces one.
Jasper Loren - Responder Compartilhar
where can we buy the replacement fan? Is there a part number for finding this part?
Rekhender Dhawan - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 13
Últimos 30 dias: 74
Ao todo: 10,457
