Ir para o conteúdo principal
Beiens Cartoon RC Race Car LED Light Replacement
O que você precisa
  1. Beiens Cartoon RC Race Car LED Light Replacement, LED Light: passo 1, imagem 1 %32
    • Hold the remote control with the backside facing you and, using the Phillips #00 screwdriver, unscrew the six 6.5 mm screws on the back of the controller that hold it together.
    Pergunte ao FixBot
  2. Beiens Cartoon RC Race Car LED Light Replacement: passo 2, imagem 1 %32
    • Open the remote control.
    Pergunte ao FixBot
  3. Beiens Cartoon RC Race Car LED Light Replacement: passo 3, imagem 1 %32
    • Lift the motherboard to separate it from the remote control.
    Pergunte ao FixBot
  4. Beiens Cartoon RC Race Car LED Light Replacement: passo 4, imagem 1 %32
    • To remove the light, use a soldering iron to heat the solder to a liquid and loosen the leads.
    • While the solder is liquid, lightly pull on the LED to remove it from the motherboard.
    • The soldering iron will get very hot while it's in use. Be sure to place it on top of a heat protected surface and be careful not to touch the operational end.
    Pergunte ao FixBot
Conclusão
Amber Ashley
Membro desde: 10/01/15
365 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 1-6, Leahy Fall 2015 Membro de USF Tampa, Team 1-6, Leahy Fall 2015
USFT-LEAHY-F15S1G6
3 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 46
Ao todo: 572
